flamebo57 Posted June 12, 2006 Report Share Posted June 12, 2006 I know that the T-bird had hydraulic brakes but apart from that are there any other differences e.g frames size? Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted June 12, 2006 Report Share Posted June 12, 2006 I don't think there's any difference. Apart from the T-Vee having V mounts, and the T-Bird having 4-bolt Magura Mounts. Quote Link to comment Share on other sites More sharing options...
unicycle boy Posted June 12, 2006 Report Share Posted June 12, 2006 I'm not sure about measurements but I have ridden both (2005 versions) and I found almost no differance except the brakes and the way the owners set them up. Although they may be some other differances I didn't notice. Quote Link to comment Share on other sites More sharing options...
mod 92 Posted June 12, 2006 Report Share Posted June 12, 2006 I know that the T-bird had hydraulic brakes but apart from that are there any other differences e.g frames size?[/quoteno there is no difference in the fram sizes but the t-brid is alot better by the brakes by far Quote Link to comment Share on other sites More sharing options...
onzaboy scott Posted June 12, 2006 Report Share Posted June 12, 2006 I know that the T-bird had hydraulic brakes but apart from that are there any other differences e.g frames size?The diffrenc between the bikes are that an onza t-vee has a smaller 20inch back wheel and has avid vee brakes and the t-bird has hydrolic brakes and has a 19inch back wheel.Plust the t-bird is a stonger frame and is more upgraded. onzaboy scott Quote Link to comment Share on other sites More sharing options...
ashby-trials Posted June 12, 2006 Report Share Posted June 12, 2006 no differences at all except brakes Quote Link to comment Share on other sites More sharing options...
Mitch A Posted June 12, 2006 Report Share Posted June 12, 2006 The diffrenc between the bikes are that an onza t-vee has a smaller 20inch back wheel and has avid vee brakes and the t-bird has hydrolic brakes and has a 19inch back wheel.Plust the t-bird is a stonger frame and is more upgraded. onzaboy scottYep V brakes and 20inch backwheel instead of the usual 19" CheersMitch Quote Link to comment Share on other sites More sharing options...
flamebo57 Posted June 12, 2006 Author Report Share Posted June 12, 2006 Thanks for all your feedback What would be so good about having a 19" wheel as apposed to a 20"? Quote Link to comment Share on other sites More sharing options...
BIG L Posted June 12, 2006 Report Share Posted June 12, 2006 (edited) there is actually quite a bit of difference lets start with the simple bits the onza t vee has avid vee brakes the t bird has maggies the onza t birds frame has four bolt mount and is stronger the t bird has a rear 19"x2.5" reggie and ronnie hog drilled rim where as the t vee has a normall onza rim 20"x2.4" and the front wheel the t bird has a 20"x2.25" hog drilled reggie and ronnie rim where as the t vee has a standered onza 20"x2.25" and im pretty sure thats all i hope ive helpedand the advantage of having a 19 inch back wheel is that there is more surface area with a thickness of 2.5" instead of 2.4"Cheers BIG L Edited June 12, 2006 by BIG L Quote Link to comment Share on other sites More sharing options...
the judge Posted June 12, 2006 Report Share Posted June 12, 2006 there is actually quite a bit of difference lets start with the simple bits the onza t vee has avid vee brakes the t bird has maggies the onza t birds frame has four bolt mount and is stronger the t bird has a rear 19"x2.5" reggie and ronnie hog drilled rim where as the t vee has a normall onza rim 20"x2.4" and the front wheel the t bird has a 20"x2.25" hog drilled reggie and ronnie rim where as the t vee has a standered onza 20"x2.25" and im pretty sure thats all i hope ive helpedand the advantage of having a 19 inch back wheel is that there is more surface area with a thickness of 2.5" instead of 2.4"Cheers BIG L Can you convert that to punctuated English please. I think there may be some good points hidden in there, but as of yet I haven't found any. Quote Link to comment Share on other sites More sharing options...
JT! Posted June 13, 2006 Report Share Posted June 13, 2006 Obviously the brakes are different, having maguras is really helpful in trials as opposed to v's.The t-vee comes with a 20" rear wheel, nearly all mod trials bike these days have a 19" rear wheel, the fatness of the tyre makes up for the extra inch. Having a 20 rear wheel makes the bike difficult to upgrade, so not only do you get better brakes with the t-bird, but the 19" wheel makes things alot easier when you want to start upgrading. Also having a 19" rear wheel gives you a much better riding feel.As for frame strength i don't think it's really an issue, because by the time you get good enough to start braking frames you'll have replaced it befor then anyway. I don't think there's any different in frame strength between the bird and tee as they're the same frame with the mounts welded on in different places.You should only get the t-vee if your really strapped for cash, but it's better than nothing. Quote Link to comment Share on other sites More sharing options...
