Sucram Posted June 12, 2006 Report Share Posted June 12, 2006 hi is it coloured rim tape that makes the drilled holes coloured? Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted June 12, 2006 Report Share Posted June 12, 2006 Yes.Cheers ! Quote Link to comment Share on other sites More sharing options...
Sucram Posted June 12, 2006 Author Report Share Posted June 12, 2006 Yes.Cheers !thanks do you know any where i can get blue ones?or red? Quote Link to comment Share on other sites More sharing options...
blinky Posted June 12, 2006 Report Share Posted June 12, 2006 blue tape or blue rims? try tarty bikes - www.tartybikes.co.uk Quote Link to comment Share on other sites More sharing options...
Sucram Posted June 12, 2006 Author Report Share Posted June 12, 2006 tape Quote Link to comment Share on other sites More sharing options...
Mark W Posted June 12, 2006 Report Share Posted June 12, 2006 Local hardware shop. Buy some insulating tape. Buy 2 rolls. Probably come to about 80p.Sorted Quote Link to comment Share on other sites More sharing options...
adamtrials Posted June 12, 2006 Report Share Posted June 12, 2006 If your hardcore you can paint the holes, and someone did talk abouttitanium holes a while back, Pete Wrong or something i think his name was? Quote Link to comment Share on other sites More sharing options...
onza t-pro rider Posted June 12, 2006 Report Share Posted June 12, 2006 Local hardware shop. Buy some insulating tape. Buy 2 rolls. Probably come to about 80p.Sorted Couldn't agree more Mark. I wanted red rim tape for my rear drilled rim bought 1 small roll of insulation tape and I thought it did the job better than rim tape. The cost of the tape is 35p at my hardware shop and is very worth it. Obviously if you need it for two rims you will need 2 rolls. It will cost you no more than a quid to do this.Hope this helped.Matt. Quote Link to comment Share on other sites More sharing options...
Joe_Kearney Posted June 12, 2006 Report Share Posted June 12, 2006 thanks do you know any where i can get blue ones?or red?For blue you can use Ikea bags they are waterproof and have a funky pattern on them, that's if you don't want to spend money and already have one though Quote Link to comment Share on other sites More sharing options...
ashby-trials Posted June 12, 2006 Report Share Posted June 12, 2006 why yes it is and if you want to give your rims a silver touch use tin foil as rim tape and stick celetape to the foil to hold it down Quote Link to comment Share on other sites More sharing options...
coolbeen Posted June 12, 2006 Report Share Posted June 12, 2006 Hello yes you can get coloured rim tape you can get it from tarty the rim tape is red. tartybikes.. I don't think you can get blue rim tape but just buy some blue tape it works and looks good imo. Quote Link to comment Share on other sites More sharing options...
justfuzzit Posted June 13, 2006 Report Share Posted June 13, 2006 There are many different ways to get the holes coloured. Use little squares of tape with different coloures on different holes if you want. Then just put a rim strip in there to make it not blow out. Quote Link to comment Share on other sites More sharing options...
Demon_trials Posted June 13, 2006 Report Share Posted June 13, 2006 Local hardware shop. Buy some insulating tape. Buy 2 rolls. Probably come to about 80p.Sorted couldn't agree more, often or not it turns out brighter and more elaborate, i out the first coloured layer down upside down so the sticky side isn't facing out, but the second layer the correct way so it doesn't get stuck to the inner tube and do this in black as a backing hope this helpsdemon_trials Quote Link to comment Share on other sites More sharing options...
