monty boi Posted June 11, 2006 Report Share Posted June 11, 2006 hey guys dont know if this has already been posted but will a magura hs-33 fit on my monty with my 2.7 rear tyre thanks Quote Link to comment Share on other sites More sharing options...
Greetings Posted June 11, 2006 Report Share Posted June 11, 2006 It will if you have a Monty frame. Don't know about the other frames though There should also be enough clearance to allow for the use of a booster. They're not that much wider than the standard 2.50" Quote Link to comment Share on other sites More sharing options...
Simpson Posted June 11, 2006 Report Share Posted June 11, 2006 (edited) oboiusly yes................. the 2.7 tires might not fit other framesan you may need to make your cross over slightly larger Edited June 11, 2006 by pissin_on_the_fence Quote Link to comment Share on other sites More sharing options...
Gilman Posted June 11, 2006 Report Share Posted June 11, 2006 The old monty tires are 25" vs. 26". Therefore, if it's one of those, it will not fit on any other frame then monty.I believe that the newer monty wheels are all 26".If it's going on a monty, it should fit without a problem. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 11, 2006 Report Share Posted June 11, 2006 The old monty tires are 25" vs. 26". Therefore, if it's one of those, it will not fit on any other frame then monty.I believe that the newer monty wheels are all 26".If it's going on a monty, it should fit without a problem.Not talking stock here boyo, unless monty make 2.7 stock tyres..... Quote Link to comment Share on other sites More sharing options...
monty boi Posted June 11, 2006 Author Report Share Posted June 11, 2006 ok cheers guys thats put my mind at ease ! Quote Link to comment Share on other sites More sharing options...
monty221pr Posted June 14, 2006 Report Share Posted June 14, 2006 i have a 2.7 on my 221pr and my brother also has a 2.7 but it is on an echo team with the team two bolt booster and all seems to fit/work fine hope i have helped Quote Link to comment Share on other sites More sharing options...
