onza t-pro rider Posted June 11, 2006 Report Share Posted June 11, 2006 Hey guys just wondering whether these bolt would be sufficient length and the right size for my rear magura with out a booster.BoltsCheersMatt. Quote Link to comment Share on other sites More sharing options...
tom tom Posted June 11, 2006 Report Share Posted June 11, 2006 tartyif you take postage into consideration it will be about the same, and there will be no problems if they arnt Quote Link to comment Share on other sites More sharing options...
onza t-pro rider Posted June 11, 2006 Author Report Share Posted June 11, 2006 tartyif you take postage into consideration it will be about the same, and there will be no problems if they arntThere for 4 bolt booster with the spacers. Quote Link to comment Share on other sites More sharing options...
Barbra Posted June 11, 2006 Report Share Posted June 11, 2006 tartyif you take postage into consideration it will be about the same, and there will be no problems if they arntThere for 4 bolt booster with the spacers.Are they I hope they are i need new ones with spacers Quote Link to comment Share on other sites More sharing options...
watto Posted June 11, 2006 Report Share Posted June 11, 2006 Even if they are slightly too long you could always cut a bit off ive done that many 'o' times to mine bolts . Quote Link to comment Share on other sites More sharing options...
onza t-pro rider Posted June 11, 2006 Author Report Share Posted June 11, 2006 Are they I hope they are i need new ones with spacers If you read the description you will see that it says for booster also i'm using 30 mm bolts with out a booster at the moment and there fine just needed new 1's as mine are starting to round off.Bought some now topic can be closed thanks for your help.Matt. Quote Link to comment Share on other sites More sharing options...
Dr Greenthumb Posted June 11, 2006 Report Share Posted June 11, 2006 oooooooooooooohShould have Pm'd Dave85he makes some bitching bolts for you Quote Link to comment Share on other sites More sharing options...
