Help Me! Look In
Hi, the other day my bottom bracket came through the post with my zona bash plate for my bike which i am building up. The length of the bottom bracket is 127.5mm which is the only bottom bracket that I can get to fit as 122.5 was to small. So I fitted it all on tightened my cranks to my bottom bracket put on my bash plate and my freewheel is not covered the by that bash. I'm running a 18t eno trials freewheel on onza musleman cranks. My cranks bolts are done up as tight as possible by my dad so that is not the issue. The freewheel sticks out about 5mm.
So what I want to know is will this be ok?
Will it cause any damage to my eno?
Thanks for any help in advance.
Cheers Matt.
Start with:
a vice,
a crank puller,
a freewheel tool,
possibly a freind/dad,
an almighty gurn*
Pop off the crank arm, fit the f.w tool in the vice lock the f.w onto the vice and use the crank for extra leverage *insert gurn here* (friend/dad usually helps) and spin it off
*optional, but it helps
Edited by ogre
Cheers Matt.
It should be ok! but the only problem is you will keep catching you trousers in it!
