Joe Aston Posted June 1, 2006 Report Share Posted June 1, 2006 I recently found that my back break lever would not come out after i pulled it in i have recently removed the lever blade don't no if this has caused the problem. I need to know what i have done wrong and how to fix it. I have no idea what to do. All help is aprcated thanks. Joe Quote Link to comment Share on other sites More sharing options...
fruitbat Posted June 1, 2006 Report Share Posted June 1, 2006 (edited) Chances are you have done exactly what i have done,,,crushed the lever meaning the piston isnt running flush with the inside of the lever bodyIf you can get the lever off and take the piston out trying getting rid of any crap in there and oiling it up good and property, if that dont do anything it looks like a new lever is on the cards...same as i had to doFrootyEdit - just noticed you said you have removed the lever recently, you haven'y over tightended the bolt that holds the lever in place have you? Edited June 1, 2006 by fruitbat Quote Link to comment Share on other sites More sharing options...
chasthetrialsrider Posted June 1, 2006 Report Share Posted June 1, 2006 lossen of your lever bolt of you have proberly over tightened it it needs to be loose Quote Link to comment Share on other sites More sharing options...
Joe Aston Posted June 1, 2006 Author Report Share Posted June 1, 2006 oh my god im such and idiot how did i not think to check that. It was taht i just checked and it works fine now. Fell like a right idiot 2 new topics in 2 days that have bin solved in the first post that could of bin done by my self if i spent a bit of time checking things.Thanks a lot.joe Quote Link to comment Share on other sites More sharing options...
