will17will17 Posted May 29, 2006 Report Share Posted May 29, 2006 hey name/title explains all reallywill a hope gothic disc fit a magura lousie, or work when it is fitted?thanks will Quote Link to comment Share on other sites More sharing options...
phil_williams Posted May 29, 2006 Report Share Posted May 29, 2006 hey name/title explains all reallywill a hope gothic disc fit a magura lousie, or work when it is fitted?thanks will I don't see why it whould`t fit just get the same size that your running and your away to go Quote Link to comment Share on other sites More sharing options...
ashby-trials Posted May 29, 2006 Report Share Posted May 29, 2006 yes it would it fit but it could involve getting your disc bleeding well see what happens biff has got 1 on his t-pro and it looks stunning Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted May 29, 2006 Report Share Posted May 29, 2006 yes it would it fit but it could involve getting your disc bleeding well see what happens biff has got 1 on his t-pro and it looks stunning Why would he have to bleed his brake then? Quote Link to comment Share on other sites More sharing options...
Krisboats Posted May 29, 2006 Report Share Posted May 29, 2006 Why would he have to bleed his brake then?Seconded. Thats about as usefull as saying you need to change your rear inner tube because you've got ne grips So long as the rotor is the right size or you get a bigger rotor with the correct adapter it will be fine. Quote Link to comment Share on other sites More sharing options...
ned1 Posted May 29, 2006 Report Share Posted May 29, 2006 were can you get these discs from?thanks alot Quote Link to comment Share on other sites More sharing options...
onza t-pro rider Posted May 29, 2006 Report Share Posted May 29, 2006 I would have thought it would fit fine as long as the rotor is the same size and the last one you had. Quote Link to comment Share on other sites More sharing options...
Simpson Posted May 29, 2006 Report Share Posted May 29, 2006 were can you get these discs from?thanks alotyou have to contact hope directly i do belive Quote Link to comment Share on other sites More sharing options...
ChrisRoo Posted May 29, 2006 Report Share Posted May 29, 2006 are u thick of course it will providing it is the right diameter even i knew that !from your good friend Quote Link to comment Share on other sites More sharing options...
will17will17 Posted May 30, 2006 Author Report Share Posted May 30, 2006 (edited) Cheers people who gave advise, sept for the stupid newbies who all just say, "it will if its same size", just trying to get validated.....but i kind of guessed if the disc was same size it would fit i was just wondering about the bolts, if they are spaced out the same on magura disc's and hopes?but they are right?thanksWill(and chris shut up haha, its better to check than to waste money if you get me and its not exactly the most stupid post on here is it now)Will EDIT: Oh yeah and to get then you have to phone hope i'm sure..... Edited May 30, 2006 by will17will17 Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted May 30, 2006 Report Share Posted May 30, 2006 obviously, there is only 1 standard 6 hole size for discs and disc hubs Quote Link to comment Share on other sites More sharing options...
will17will17 Posted May 30, 2006 Author Report Share Posted May 30, 2006 thanks but don't sound like you mean to bragg i think you need to pull your head out mate!!Thanks anywayWill Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted May 30, 2006 Report Share Posted May 30, 2006 obviously, there is only 1 standard 6 hole size for discs and disc hubsthere is more than 1 disc mounting method, for example the splined system used by shitmano or the old style 5 bolt rotors by hope as quick example-theres also a few disc hubs that are 6 bolt and need a rotor to be modified slightly to fit-like the goldtech rear hubsanyway, i wouldnt bother with a gothic personally, i had 1 and it made my brake suck, they also make the brake really stuttery, instead of smooth-as the pads catch on the edges-thats my experience with them anyway, others may have got along fine Quote Link to comment Share on other sites More sharing options...
Fvil Posted May 30, 2006 Report Share Posted May 30, 2006 gothic diskwowwt does it look like???nhow much???n where can u buy it??? Quote Link to comment Share on other sites More sharing options...
trial-biker-ryan Posted May 30, 2006 Report Share Posted May 30, 2006 dont know about them gothica disks but the magura louise is an awsome brake to have!! Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted May 30, 2006 Report Share Posted May 30, 2006 thanks but don't sound like you mean to bragg i think you need to pull your head out mate!!Thanks anywayWillf**k off, when you have been here as long as I have then you can critisize me, but as you still in NMC, shut itthere is more than 1 disc mounting method, for example the splined system used by shitmano or the old style 5 bolt rotors by hope as quick example-theres also a few disc hubs that are 6 bolt and need a rotor to be modified slightly to fit-like the goldtech rear hubsanyway, i wouldnt bother with a gothic personally, i had 1 and it made my brake suck, they also make the brake really stuttery, instead of smooth-as the pads catch on the edges-thats my experience with them anyway, others may have got along fineobviously, there is only 1 standard 6 hole size for discs and disc hubsI don't care about other mounting methods, there is only 1 standard 6 hole size you discs. Quote Link to comment Share on other sites More sharing options...
adamtrials Posted May 30, 2006 Report Share Posted May 30, 2006 It is a valid question as potentially hope disks could be thicker than magura disks, meaning they wouldnt fit, or some other variables.They arent thicker, but to all those who said "r u think or summat" he was right to ask the question... Quote Link to comment Share on other sites More sharing options...
Krisboats Posted May 30, 2006 Report Share Posted May 30, 2006 (edited) f**k off, when you have been here as long as I have then you can critisize me, but as you still in NMC, shut itAwesome, i can critisize you.. nobhead Only messing, i think you, snappel and boumsong make threads worth reading.. its great looking through a thread and seeing some random comment from you! I also like simons posts when he critisizes people, though i don't know whether his are intended to be sarcastic or not EDIT: forgot davetrials.. his posts usually make me crease as well Edited May 30, 2006 by Krisboats Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted May 30, 2006 Report Share Posted May 30, 2006 are u thick of course it will providing it is the right diameter even i knew that !from your good friendOT but still valid.Wanna get validated? Then be quiet. And what are you on about anyway? "Are you thick, of course it'll fit, providing it's the right size, even I know that". Of course you know that, you'd have to be retarded not to know that if something that's the right size will fit something else. It's like me saying any key will open a lock, providing it's the right shape. Quote Link to comment Share on other sites More sharing options...
Barbra Posted May 30, 2006 Report Share Posted May 30, 2006 are u thick of course it will providing it is the right diameter even i knew that !from your good friendits a good job you said that...otherwise i'd of gotten chuck norris at a keyboard on your ass! Quote Link to comment Share on other sites More sharing options...
