marcus123 Posted May 27, 2006 Report Share Posted May 27, 2006 hi what would be better to put on a onza t pro. a rear magura julie disc brake or a rear hs33? Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted May 27, 2006 Report Share Posted May 27, 2006 (edited) Since when did t-poos have rear disk mountsi don't think they do so it looks like your only option would be hs-33 Edited May 27, 2006 by Gavyn L Quote Link to comment Share on other sites More sharing options...
roby James124 Posted May 27, 2006 Report Share Posted May 27, 2006 Since when did t-poos have rear disk mountsi don't think they do so it looks like your only option would be hs-33Hi I think he means a front disc otherwise he could of had some welded on.Could you give us some more infomation like have you already got a front disc hub and disc forks. Rob Quote Link to comment Share on other sites More sharing options...
Ride or die Posted May 27, 2006 Report Share Posted May 27, 2006 Since when did t-poos have rear disk mountsi don't think they do so it looks like your only option would be hs-33You mean T-pro.. Learn to spell Quote Link to comment Share on other sites More sharing options...
bikerben Posted May 27, 2006 Report Share Posted May 27, 2006 na mate t-poos dont have disk mounts on the back.you might be able to get some welded on but it might weaken your frame!rear hs33 and a disk on front if you like the julie and you have the money thengo for itcheers ben Quote Link to comment Share on other sites More sharing options...
