Guest Posted May 26, 2006 Report Share Posted May 26, 2006 in am getting sum cheap carbon fiber sheet of a mate and just need sum ansers 1 i am making a booster do i need to cut lots of layers and glue them to getter or do i fold it over and over 2 do you now a good we site that explains what to do,3 what have you made out of the stuff. if you have can you bung up a pic so i can see it4 i did not do a search as it takes to long to go throe it all i hope all the spellings are ok thanks the ug man Quote Link to comment Share on other sites More sharing options...
Josh!! Posted May 26, 2006 Report Share Posted May 26, 2006 if i was you i would cut out some alluminum or whatever metal you would lik get it the right thickness and shape it file it drill do what you want and then cover it so it looks like carbon fibre josh ....................... Quote Link to comment Share on other sites More sharing options...
King C Posted May 26, 2006 Report Share Posted May 26, 2006 Surely your friend will know how it works. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted May 27, 2006 Report Share Posted May 27, 2006 google "Carbon Fibre Construction"Theres plenty of info there and the spelling was quite bad by the way but not the worst here Quote Link to comment Share on other sites More sharing options...
adamtrials Posted May 27, 2006 Report Share Posted May 27, 2006 Has it already been laminated, or is it just the carbon fibre fabric that you have? Quote Link to comment Share on other sites More sharing options...
Guest Posted May 28, 2006 Report Share Posted May 28, 2006 i have sum carbon fibre fabric Quote Link to comment Share on other sites More sharing options...
monty221pr Posted June 1, 2006 Report Share Posted June 1, 2006 To be honest you are probably best off using some steel,aluminium or maybe even titanium for your booster and if i was you i would just use the carbon fiber for protection under your frame for instance or under the chain stays. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted June 1, 2006 Report Share Posted June 1, 2006 Making a good booster would be difficult. Take the Heatsink ones for example. Look at all the testing Steve did, to ensure that they did the right job. Good luck to you. Quote Link to comment Share on other sites More sharing options...
