Hey Need Help With Stripping My Frame
onzatprodude
i put a topic up about nitro mors ages ago and eventually i went out and bought some and was planning on doing it tonight but my dad said i need laka to stop the frame from rusting but i was wondering if i would be able to just laka it another day like sunday? even though ill be riding it tomorrow will it get rusty? and also will it be better keeping it in the house over night?
needing quick replys lads...
cheers
Edited by onzatprodude
1st - You should laquer it, as laquer is a anti corrosion stage, just like paint, it not only looks good but its there for the reason to prevent corrosion.
2nd- keep it in doors, becuase moisture = corrosion (hardly any though, but its a start)
3rd - You should at least spray it with an Etch primer, thats primer for bare metal, then when you get a chance to laquer it, rub your frame down with a 320 grit paper and then a 500 git and then maybe even a wet 800 for extra smoothness because your only laquering it, then laquer it and your laughing (Y)
Hope that helps mate (Y)
Steve :)
It's alu so it's not going to rust ... my T-rex has been polished all down and hasnt be laquerd and it's fine. But use laquer just for extra protection if you like don't really matter as it's alu so it's not going to rust at all.
Looking good Fergie, You just gotta ride it now ;) And give me a go..
Also, no need to laquer it, I didn't laquer my T-Rex frame and my ashtons and theyre both fine, I just give it an occasional polish to get the bling going.
Good outcome, looks nice. if i was you i wouldent use polish on it when it's like that i think it looks really nice like that with out polishing it ... but it'll start going dim and and shitty so thats when you need to give it a polsihing. Looks really nice anyway.
Done a good job (Y) .
