Clicking Cranks
Jason
Everytime I pedal down the cranks/bb gives a clicking noise. I'm running some echo cranks (6061 forged) on a shimano? bb (square tapered [FFW]) on my t-pro.
Any idea what this is/how to fix it?
PS: this is a different noise to the creaking noise... I've had that before :D
Edited by Jason
hmm correct me if im wrong, but isnt it grease for isis, and clean with no grease for tapered........
best bet is to take the bb out, clean the threads and re grease, re tighten to the write torque and then clean crank tapers and bb and fit back on.
If it still creaks, unlucky, could be the bb or cranks or even a dry weld on the frame. if your sure theres no cracks...
I had the same problem...take your cranks off clean the tapers on your bb,then stick some grease on them that's what i did and now i just hear lots of eno...Hope this helps somebody
zoo baby!
I'd say there was more trouble with creaking with no grease on square tapered, 'cos there's mre movement in the cranks? Either way, it's not a bad thing to use grease, and it certainly quietens things down.
Just a quickie - are the two people with problems running ACS Claws?
Does it click when you spin the cranks by the crank arm themselves, or does it only do it when you spin it by the pedals?
Its only when i put pressure on the arms, E.g. peddling, I know it isnt my pedals as it done the same with my old ones! :P
Well, just try tightening your cranks a touch then, or just strip 'n' grease basically. Like I said, the clicking is metal-on-metal rubbing, which'll be caused by something being fractionally loose, usually...
Took off, cleaned, regreased everything; except the freewheel :- and now it seems the freewheel is rubbing against the bb, making it near impossible to turn the cranks :blink: and I've checked the chain tension (it's not that making it stiff to turn), but it just really hard to turn. I took the right crank off... and everything ran smooth, so its not a case of the bb not turning. The freehweel and the bb are both done up nice and tight as well..... (not too tight).
I'll have a look at the alignement, cheers for the help so far lads :)
Edited by Jason
That sounds like you've overtightened the right arm then, and stretched the tapers a little. Welcome to the fun world of square taper (Y) Mine did exactly the same so I could only use a Dicta on my cranks for a year and a half. How much fun d'you reckon that was? :P
When you said you didn't do the BB up too tight, how do you mean? You can never really over-tighten a BB unless you strip the threads on the frame or something, and them being either feeling tight or loose tends to just be the bearings being shit, good, or shit again. What did you use to grease them up?
My bike make an almost sorta clicking/knocking noise every pedal stroke that turned out to just be my ACS Claw freewheel being shit and open bearing. Solved that one by getting my Eno back on...
Yeh that sounds about right, because it spins nicely before I do that last little turn on the crank bolts.
I've tried it with the bb nice and tight, and just hand tight and neither are really effecting it. Just used some grease to tighten them.. *Castrol LM Grease* :unsure: And yea its an ACS Claw :$ Cant really afford an eno at the moment :lol:
EDIT:// New bb??
Edited by Jason
I really wouldn't run the BB hand-tight. Like I said, the tightness of the cups shouldn't affect the BB that much, unless it's open bearing or something. 'cos it's a sealed unit, the bearings will do preeeeeeeeetty much what the bearings want. Therefore, the looser your cups are the more chance there is of creaking or anything 'cos they'll have more play between the cups and the BB shell.
Did you remember to put a spot of grease inside the left-side cup as well? My FSA ISIS BB occassionally clicked like a King until I put some in there...
Could always go for a Tensile if you can't afford the Eno I guess, but to be honest, that may not solve your problem...
Nah, sorry, I meant the tapers inside your crank arm. The crank arm material is softer than the BB spindle, so when you get the hammer down and tighten it up savagely, the crank arm tapers expand to cope with being forced on further. Therefore, they sit further in on the spindle. This kinda means you need a new crank arm though :(
:angry: darn. Would a dicta freewheel suffice? I mean is it thinner than an ACS? I've literally just got these cranks (N)
I had this on my control for months, I also thought my forks were cracked, but it turned out my headset was knackered. change that and see if it makes a difference
Ah, im getting random clicking from the forks, its annnoying me loads and there deffo not cracked.
Ill have to have a look at the headset.
The Dictas aren't really worth using. The Tensile is just as thin, but a hell of a lot better, basically.
as long as it's thin enough to make a difference? I don't wanna fork out for that if it doesn't fix it :mellow:
