Leeson
tillz
If you are running magura mounts. You may round the freads in them, dont worry you can buy nuts from any hardware store. To fit inside the square part of the mounts and makes the brake alot tighter.
If you are having bolts instead of a skewer for the rear wheel, dont tighten them to tight, or they will snap.
Just sum things i had problems with.
shrewers
