liam-pantera Posted May 23, 2006 Report Share Posted May 23, 2006 Hi everyone im having quite abit of trouble with my 2006 echo cnc headset, at the min it rocks constantly regardless of how much u tighten it up and if u turn the bars the headset makes a loud crack.I spoke to a few more people and they said that they are having problems to,so please can anyone help me. Quote Link to comment Share on other sites More sharing options...
Hobnobs Posted May 24, 2006 Report Share Posted May 24, 2006 Probably put together wrong? No base plate? Duff headtube? Quote Link to comment Share on other sites More sharing options...
Camster911 Posted May 24, 2006 Report Share Posted May 24, 2006 just sounds like another 2006 echo product to me... Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted May 24, 2006 Report Share Posted May 24, 2006 Fork race on properly?Did you do the top cap up before the stem bolts?Is everybit there?Maybe uses a spacer or take one out and try that? Quote Link to comment Share on other sites More sharing options...
joewhite Posted May 24, 2006 Report Share Posted May 24, 2006 Right, there a few reason whys this could happenNo bottom bearings (ive done it before)Flared headtubecracked/snapped/damaged headset?have a look joe Quote Link to comment Share on other sites More sharing options...
SamHolmes Posted May 25, 2006 Report Share Posted May 25, 2006 Happened to mine aswell, probably just needs properly tightning up though Quote Link to comment Share on other sites More sharing options...
Trials Dave Posted May 25, 2006 Report Share Posted May 25, 2006 ok then, is it hard to turn the bars from side to side? if they are then your bearings may be in upside down. i did this with an fsa pig.your top cap isnt touching the top of your steerer tube on forks? if so tightening it will just pull the star nut up.all parts are there in correct order?the headset is pressed in all the way? and in straight?theres a few things for you to check Quote Link to comment Share on other sites More sharing options...
Adrian Posted May 25, 2006 Report Share Posted May 25, 2006 right my mate alex has had exactly the same problem; the rocking was just the pads on the front maggie moving back and forth, and the cracking has never stopped and we've checked everything, now it click about 10 times wen you turn thr bars 90 degrees... ive also got an echo headset and its lush, so i just think its the odd few.... adrian Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted May 25, 2006 Report Share Posted May 25, 2006 In my opinion, no product should crack or rock or anything, that is why companys hold checks where they take 1 or 2 from each batch and check they workand meet specs. Echo seem little quality, Damn Deng Quote Link to comment Share on other sites More sharing options...
dave85 Posted May 25, 2006 Report Share Posted May 25, 2006 Get the headtube faced, ditto the fork, then cover everything in sight with grease, should sort it. Quote Link to comment Share on other sites More sharing options...
modrider666 Posted May 25, 2006 Report Share Posted May 25, 2006 Mates did it,Greased all the bearings etc and stopped crackingabout the rocking make sure the top cap isnt bottomin out on the steerer basically add spacers if needed or shorten the steerer tube:) Quote Link to comment Share on other sites More sharing options...
