Need Some Help.
Greeny
right..
i need some new tires for my zoo! i am riding with creepy crawlers at the moment, but i don't no if to get some try all tires but they are more expensive. is it worth paying extra £20 for try all's or should i stick to creepy crawlers? what would you do..
also..
is it worth up grading my cranks and bottom bracket to isis or shall i stick with a square taper with standard echo cranks?
also
i am thinking of spraying my bike a different colour its a zoo! python which is silver at the moment with gold headset (hope), and gold hubs (hope on front and profile on back) what colour would you spray it or shall i stick with silver.
thank you
Greeny
right..
also..
also
thank you
Greeny
1. stick with creepy crawlers, they last longer
2. if your crank and bb have had it then yes upgrade but if they haven't, then dont waste money
3.stick with the silver frame, firstly u can really scratch metal off to leave a mark, and secondly if u mess up the paint job your bike frame will look messy. (Y)
Then again its our choice, u choose, im only giving advice :P
Well. as far as spraying it, i would stick with the current color if its not too banged up. if you do, however. get it powdercoated or something. if you just spray it with paint it might not last very long. Personally i like the looks of the python as is.
ok thank you for the people who have posted so far a lot of people have been telling me to stick with the silver frame.
if i was to get it painted i would take it down to were i work were it can properly sprayed in a spray booth
thank you again
Greeny
since you asked for advice i'm sure you don't mind us giving it
you can buy about 2 sets of creepys for 1 set of try-alls and creepys last longer so technically i would go with them, riding them my self and i have a friend with a zoo who is also riding them and they have lasted very long compared to a review on try-alls i did about a week ago.
Leave the frame the same zoo's look smart as they are unless 26" but you don't got 26" because they don't do creepy's in 26" i'm guessing?
and don't waste money so technically i have a friend who has bent his bottom bracket (Sq tapper) and he is only replacing the BB instead of a whole new set of cranks because it is a waste of money since the cranks still work ;) you get me
Thanks *Greeny* hoped this helped
Will
nice gold profile i got a red one myself, bet you could of never guessed ;)
I also bet you bike looks well nice gold and silver if you got you hubs built on onza ronnies and reggies?
also do you got a gold hope squ-er through your front disc hub?
For the tyres,I'd personally stick with the Maxxis CC's.
Just as good, and cheaper.
For spraying the frame, choose whatever coour you want.
I made a topic before i sprayed my one, to get an idea on colours, and then I played about in photoshop to get the colour sorted.
It's really not hard to spray frames, just get all the paint off (in your case stickers and lacquer?) and the primer it, then the coats of the paint of your choice, the lacquer. (Y)
EDIT: For the bottom bracket, if your Square taper is fine, leave it. (Y)
Edited by Dan6061
