BeNNy Posted May 21, 2006 Report Share Posted May 21, 2006 Right....For the past 45 minutes or so, ive been trying to remove my rear tyre...It just wont come off I've snapped a tyre lever and have tried many techniques...The closest i can get is getting one side of the sidewall to come out with a screw driver, After that ive tried pulling it up and down...normally it just goes and one side of the tyre comes off, but this one is gay...it just gets stuck in that position Help me pleaseeeeeeeee Benny. Quote Link to comment Share on other sites More sharing options...
Lee Cable Posted May 21, 2006 Report Share Posted May 21, 2006 crowbar, thats all i can suggest, u tried using washing up liquid round edge of rim, also helps! Quote Link to comment Share on other sites More sharing options...
Houseface Posted May 21, 2006 Report Share Posted May 21, 2006 did you use one or 2 screw drivers?if you only used one, get 2 put one in and hold it there then get the other one and do the rest of the sidewalls next to the other screwdriver steve. Quote Link to comment Share on other sites More sharing options...
onzatprodude Posted May 21, 2006 Report Share Posted May 21, 2006 try a bit of lubricant something like fairy liquid to ease it off Quote Link to comment Share on other sites More sharing options...
Deonn h Posted May 21, 2006 Report Share Posted May 21, 2006 Use knifes Quote Link to comment Share on other sites More sharing options...
Guest Posted May 21, 2006 Report Share Posted May 21, 2006 Give it some pasty!!! Quote Link to comment Share on other sites More sharing options...
BeNNy Posted May 21, 2006 Author Report Share Posted May 21, 2006 crowbar, thats all i can suggest, u tried using washing up liquid round edge of rim, also helps!Crowbar? Havent tried using any fairy liquid yet...Gonna try when my hands stop hurting.Thanksdid you use one or 2 screw drivers?if you only used one, get 2 put one in and hold it there then get the other one and do the rest of the sidewalls next to the other screwdriver steve.I used 1, I'll try using 2 in a minute Thanks.. Quote Link to comment Share on other sites More sharing options...
Rich J Posted May 21, 2006 Report Share Posted May 21, 2006 Do you want to keep the tyre? If not then you could just get out a stanly knife and cut across the tyre, unless you have wire beeded side wall then you could struggle!! Quote Link to comment Share on other sites More sharing options...
BeNNy Posted May 21, 2006 Author Report Share Posted May 21, 2006 Do you want to keep the tyre? If not then you could just get out a stanly knife and cut across the tyre, unless you have wire beeded side wall then you could struggle!!Yeah, want to keep it Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted May 21, 2006 Report Share Posted May 21, 2006 It's not a Hog and a CC is it? .That IS a b*****d to get off.Mat Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted May 21, 2006 Report Share Posted May 21, 2006 20" or 19"?try some metal leversLower the psi compleltley by squashing it all the way round whilst pushign the valve in Quote Link to comment Share on other sites More sharing options...
BeNNy Posted May 21, 2006 Author Report Share Posted May 21, 2006 It's not a Hog and a CC is it? .That IS a b*****d to get off.MatYeah it is a Hog BUT...got it off now! THANKS!! Used the fairy liquid tehnique Did it in 5 minutes!Thanks guys Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted May 21, 2006 Report Share Posted May 21, 2006 remember clean it offw ith lots of hot water and a brush or summit.or else be prepared for bad brakes for eternity, lol. Quote Link to comment Share on other sites More sharing options...
BeNNy Posted May 21, 2006 Author Report Share Posted May 21, 2006 remember clean it offw ith lots of hot water and a brush or summit.or else be prepared for bad brakes for eternity, lol.Yeah, when i split my rear hose, the fluid went all over my rim, i didnt wash it off with hot water Brake was crap crap crap Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted May 21, 2006 Report Share Posted May 21, 2006 Yeah, when i split my rear hose, the fluid went all over my rim, i didnt wash it off with hot water Brake was crap crap crap well, in the case when ur brake fluid went on the rim, you'd of probarbly needed a degreaser aswell.but since fairy liquid is a degreaser, hot water will do Quote Link to comment Share on other sites More sharing options...
Lee Cable Posted May 21, 2006 Report Share Posted May 21, 2006 Yeah it is a Hog BUT...got it off now! THANKS!! Used the fairy liquid tehnique Did it in 5 minutes!Thanks guys Whos the daddy! Quote Link to comment Share on other sites More sharing options...
poopipe Posted May 21, 2006 Report Share Posted May 21, 2006 Whos the daddy! it's doable with just your fingers you know- i didn't believe whoever it was that claimed to be able to do it a few months back but I've done it twice now. Its all about getting the big thick rimmy bit of the tyre into the middle of the rim. It hurts like buggery though so I much prefer a trip to the kitchen drawer for some forks. Quote Link to comment Share on other sites More sharing options...
