How Are The Echo Components?
Echo don't do freewheels.
The hubs have just started to come out now as they had a few problems it appears.
I made a topic a while ago asking about the External BB's and they seem to be problem free. :)
A certain type of Echo crank seemed to strip ASAP, but people's stories about which particular ones they are change like the wind ;)
Their rims also seem to not be that great - many people seem to have a lot of troubles with them, especially the 26" rims.
Personally, for cranks I'd either stick with Middleburns, Tensiles or maybe Zoo's, and rims would probably just be Try-Alls or similar. The DX-32s are still really great rims though, if you can get one and still have a working back brake...
Ian
Due to the fact the DX-32s have a narrower profile, it means you're kinda pushing it a bit with a 4-bolt Magura. Or so I found? Not enough piston to get the pads close enough to the rim, basically.
My ronnie rim is 38mm i have no problems what so ever with my pads reaching the rim :ermm:
Ive heard that the earlier echo cranks had a problem with bending but the new ones are fine. The new rims are ok but arent the strongest so be carefull. They do look great though
