Infurnass Posted May 17, 2006 Report Share Posted May 17, 2006 ive got an echo bb do i need the green spacers on it cause it makes my bb feel stiff when i have them on im running a freewheel on the front Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted May 17, 2006 Report Share Posted May 17, 2006 I thought you couldn't run front freewheel with the new Echo BBs?Or is it an old one? Quote Link to comment Share on other sites More sharing options...
Infurnass Posted May 17, 2006 Author Report Share Posted May 17, 2006 I thought you couldn't run front freewheel with the new Echo BBs?Or is it an old one?its an old one Quote Link to comment Share on other sites More sharing options...
anzo Posted May 17, 2006 Report Share Posted May 17, 2006 I ran a FSA B.Bracket (plat) and didnt use the spacer, although after a month or so the crank stared coming really loose, I tightened it and it was still loose...obviously, fitted the spacer and you can guess the rest...so yes, use it if you NEED to, but you might be able to get away without using it.. Quote Link to comment Share on other sites More sharing options...
