MasterOfGussets Posted May 16, 2006 Report Share Posted May 16, 2006 I've searched on the forum and on Google but can't seem to find anything definative about this...If you're mounting a HS33 onto V mounts using the EvoII "booster" can you still fit a 4-Bolt booster over the top? Or maybe leave out the EvoII mount and just put in the 4-bolt booster?For example, if I put a HS33 onto a frame with V mounts could I still use something like the Heatsink 4-bolt booster over it? With the provided bolts and spacers? Either with or without the EvoII aid?Any ideas and/or experiences would be great. Thanks. Quote Link to comment Share on other sites More sharing options...
Simpson Posted May 16, 2006 Report Share Posted May 16, 2006 You need a 2 bolt mount i ran a raceline booster with mine back in the day!! lolbut you could probably modify a 4 bolt booster? couldnt be sure Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted May 16, 2006 Report Share Posted May 16, 2006 You could use a V booster. Like the Shimano Carbon Fibre ones...etc. Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted May 16, 2006 Report Share Posted May 16, 2006 You couldent use a Heatsink booster or Echo or any of them, the only booster i know of were you can drill to fit V brake mounts with the evo mounts is a XTR carbon booster and run it like you would on a 4 bolt frame but there preety rare now as they don't make them no more. Quote Link to comment Share on other sites More sharing options...
ogre Posted May 16, 2006 Report Share Posted May 16, 2006 Magura make a booster to fit it (better than the little oval thing), i don't know where does it though sorry Quote Link to comment Share on other sites More sharing options...
