T.McMillan Posted May 16, 2006 Report Share Posted May 16, 2006 (edited) RSI, Repetitive Strain Injury,Does anybody have this problem while riding, i get it in my left hand when i brake, when i ride hard for a while using the back brake alot, my strength in my index finger just gives way and it cant brake sometimes slipping etc, i had it happen at edge of a highish drop and nearly went over handlebars, its f**king dodgy,does anybody have a similar problem?does anybody know how to prevent it? Edited May 16, 2006 by speedyjustice Quote Link to comment Share on other sites More sharing options...
stetpro Posted May 16, 2006 Report Share Posted May 16, 2006 no sorry i have never had that problem. it doesn't sound good though Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted May 16, 2006 Author Report Share Posted May 16, 2006 its not to bad its just if you have picked a long line then u got a big drop at the end it can be bad Quote Link to comment Share on other sites More sharing options...
onzatprodude Posted May 16, 2006 Report Share Posted May 16, 2006 dont know what you have but you could try using 2 fingers to make sure Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted May 16, 2006 Author Report Share Posted May 16, 2006 (edited) i dont like using 2 fingers lol Edited May 16, 2006 by speedyjustice Quote Link to comment Share on other sites More sharing options...
morton Posted May 16, 2006 Report Share Posted May 16, 2006 Yer i get that sometimes especially at the end of sections in competitions, I've found the more you ride the better your stamina gets and the less nakered you get, and you don't start to ache as much.Morton Quote Link to comment Share on other sites More sharing options...
Concussion Posted May 16, 2006 Report Share Posted May 16, 2006 1 . does anybody have a similar problem?I think I do...kinda get a `cramp` type feeling in my L hand when riding a lot. Its a right pain, all I can think off is to flex your hand a bit, and hope it gets better/stronger.I was half thinking of swapping my brakes around to solve this, as my right hand has power...but I dunno? Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted May 16, 2006 Author Report Share Posted May 16, 2006 I was half thinking of swapping my brakes around to solve this, as my right hand has power...but I dunno? the thing is if you swapped your brakes around, it would be like learning to ride a bike again, i spose it is kind of a cramp, its abit of a pain in the but, dont change your levers over Quote Link to comment Share on other sites More sharing options...
dcstephenson Posted May 16, 2006 Report Share Posted May 16, 2006 When you say RSI, do you mean a pain that comes on whilst riding and stays with you for days afterwards, or a pain that just comes on when your arm and finger muscles are really tired whilst riding and goes away with rest??? Quote Link to comment Share on other sites More sharing options...
Simpson Posted May 16, 2006 Report Share Posted May 16, 2006 Pretty sure it aint RSI mate - you get that more from typing all day everyday on a keyboard at work really fast and joint inflame i belive. try to set up your lever so it moves less? Quote Link to comment Share on other sites More sharing options...
will17will17 Posted May 16, 2006 Report Share Posted May 16, 2006 i have problems with my back since im 6ft 5" and ride a mod Quote Link to comment Share on other sites More sharing options...
Simpson Posted May 16, 2006 Report Share Posted May 16, 2006 might help you Quote Link to comment Share on other sites More sharing options...
Shaun H Posted May 16, 2006 Report Share Posted May 16, 2006 (edited) That sounds like arm pump not RSI.RSI stays with you for a few days/weeks and tends to be just a painful feeling rather than something which prevents your muscles from operating properly (ie arm pump)I had RSI in my elbows for a while I presumed it was from the combination of a new longer frame (T-Rex), mega wide Pazzaz risers and a mega harsh tapping technique. I just hope it doesn't come back now I have my stupidly long Limey... Edited May 16, 2006 by Shaun H Quote Link to comment Share on other sites More sharing options...
nickyw Posted May 16, 2006 Report Share Posted May 16, 2006 I get something like this sometime's.I get this small amount of pain and ache on both wrist's.I have to stop riding for like 20 sec's then the acheness goes away. Quote Link to comment Share on other sites More sharing options...
Si-man Posted May 16, 2006 Report Share Posted May 16, 2006 That isn't RSI, thats just arm pump because you have used that muscle to much in a short period of time/ all day.Everybody gets that.RSI is completely different Quote Link to comment Share on other sites More sharing options...
Guest Posted May 16, 2006 Report Share Posted May 16, 2006 If you has RSI, you wouldn't be able to ride. I have it, the pain is comparable to a broken bone. Quote Link to comment Share on other sites More sharing options...
Si-man Posted May 16, 2006 Report Share Posted May 16, 2006 Im supprised I don't have it after all that wanking ive been doing since I was about 11 haha Quote Link to comment Share on other sites More sharing options...
yoyoyo Posted May 16, 2006 Report Share Posted May 16, 2006 The only place i get anything like that is in the back. Just have small rests like a couple of days between each ride. See if it helps. Quote Link to comment Share on other sites More sharing options...
tank_rider Posted May 17, 2006 Report Share Posted May 17, 2006 I get what your describing, which is arm pump, caused by muscle fatigue.I also get RSI though due to the sweep on my bars, it shows as a sharpe pain in my wrists which occurs when they are under any load in certain positions. I think its a combination of riding and lots of keyboard typing. I will be getting some new bars to try to combat the problem, the doctor who diagnosed it also said to try wearing a support (which i need to get round to buying!!)For your problem, the more you ride, and longer lines you do, the situation will improve with time. I find i get the problem at comps after having ridden a few sections, due to me usually riding street and single obsticles or short lines, in comparison to two mins at a time as in comp sections. Quote Link to comment Share on other sites More sharing options...
flipkickbs Posted May 17, 2006 Report Share Posted May 17, 2006 i have problems with my back since im 6ft 5" and ride a mod Get a stock I got the same sort of thing as you while riding a comp, its just through excess use of those muscles and tendants in a short amount of time. Just rest for a day or so i reckon. Ian Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 17, 2006 Report Share Posted May 17, 2006 When you use the tendons in your arms intensively, they swell up a little and end up hitting the sheaths that hold them in place. When this happens, you're then unable to use the tendon correctly, which is what happens when you get armpump. Pro motocross racers sometimes have operations to remove the sheaths so they can ride without armpump, but it's not really worth it just to ride sections a little better at comps. I get it fairly bad, and I'm fairly sure Ali C (I know he had a load of trouble with it) and a few others have it bad too, so it's not just you.Are you using thick grips or thinner ones? And do you have your brakes set so the bite point is further out or further in? Quote Link to comment Share on other sites More sharing options...
T.McMillan Posted May 17, 2006 Author Report Share Posted May 17, 2006 sorry it was mum that told me it was RSI, i think it sounds like the arm pump where you use the muscle alot in a short amount of time, it kinda does ache my arm as well as just my L hand index finger, when i rest for a min or so it goes away, but it does come back very quickly, it just restricts me from doing a long trials line or something, or something Quote Link to comment Share on other sites More sharing options...
