wilko Posted May 15, 2006 Report Share Posted May 15, 2006 i thought i d put this for those of you that don t know how to bleed there brakes and they might want to do it instead of paying the money to get it done by a shop or someone.step 1 you first need to adjust your tpa right down to the bottom so the lever pulls in as far as it will go.step 2 you then take the bolt out of the caliper.step 3 you then set up the syringe by putting the pipe on the end .you then pump the syringe full of blood and get rid of an ar bubbles this is vital.step 4 you then screw the syringe pipe into the caliper and on the lever loosen the bolt there so it lets the old blood out.you may want to put a jug under this.step 5 you then pump the blood through until you see new blood coming out the other endstep 6 you then need to screw the lever bolt back in and pump to get it as pressurized as you can so the bleed is a god one.step 7unscrew the syringe out of the caliper and the put the caliper bolt back in and adjust the tpa to were you want itthis is only a quick bleed but i use it all the time and it works a dream Quote Link to comment Share on other sites More sharing options...
KeNi Posted May 15, 2006 Report Share Posted May 15, 2006 Yeah... Nice review, its not really a review but it helps anyway thanks Quote Link to comment Share on other sites More sharing options...
Lee Cable Posted May 15, 2006 Report Share Posted May 15, 2006 this is only a quick bleed but i use it all the time and it works a dream If you use it all the time, then it isnt a good bleed, otherwise you wouldnt need to do it all the time? Quote Link to comment Share on other sites More sharing options...
sexymike Posted May 15, 2006 Report Share Posted May 15, 2006 If you use it all the time, then it isnt a good bleed, otherwise you wouldnt need to do it all the time?lol, maybe he does his mates or its just a figure of speech? Quote Link to comment Share on other sites More sharing options...
wilko Posted May 16, 2006 Author Report Share Posted May 16, 2006 i mean i use it wen i need to bleed the brake Quote Link to comment Share on other sites More sharing options...
Simpson Posted May 16, 2006 Report Share Posted May 16, 2006 this is only a quick bleed Well isnt it the only way to bleed??? apart from oral bleed an bath / sink / submerged bleed Quote Link to comment Share on other sites More sharing options...
wilko Posted May 16, 2006 Author Report Share Posted May 16, 2006 no mi mate does it a bit different and its hard to understand it takes ages and before anyone asks its not a disk Quote Link to comment Share on other sites More sharing options...
Sam Nugent Posted May 16, 2006 Report Share Posted May 16, 2006 Argh! I know you are only trying to help but this is another pointless topic. There are too many guides to bleeding brakes around, just use the search. Quote Link to comment Share on other sites More sharing options...
wilko Posted May 17, 2006 Author Report Share Posted May 17, 2006 i have nt seen any Quote Link to comment Share on other sites More sharing options...
