duane Posted May 14, 2006 Report Share Posted May 14, 2006 Hi,I see that many people recommend the Nokon cables with a V-Brake setup, my first question is, is there any differentce between the MTB and the BMX versions, and which is most suited to trials ?And the next question, can I use a brake booster with Avid Ultimate V-Brakes, from the pictures I have seen it doesn't look as it you can ?Thanks Duane. Quote Link to comment Share on other sites More sharing options...
Caleb Posted May 15, 2006 Report Share Posted May 15, 2006 yeah you can run a booster just need to use spacers to bring the booster above the arms for clearance .still depends on your seat set up though.im running nokon cable up front and its definitely the best ive ever used.not sure about the differences between the two however Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted May 15, 2006 Report Share Posted May 15, 2006 get the bmx version, it gives you a full outer, the mtb doesnt and makes you use the cable stops-which sucksas for boosters, i have run boosters with 5mm spacers and they have been fine on my ultimates dont really need a boooster wiht a v though, unless you have a really shite frame nokons really are the tits and will totally transform your brake Quote Link to comment Share on other sites More sharing options...
duane Posted May 16, 2006 Author Report Share Posted May 16, 2006 Thanks for the replies, I would have got the MTB cables which won't work with my Base 26, so that has saved me some trouble, especially as I live in Dubai. Thanks Duane. Quote Link to comment Share on other sites More sharing options...
