TheChai Posted May 13, 2006 Report Share Posted May 13, 2006 does anyone know where i can get those standard sealed bearings for monty/echo/tryall hubs? mine have been wobbling for ages... thanks Quote Link to comment Share on other sites More sharing options...
ogre Posted May 13, 2006 Report Share Posted May 13, 2006 mine have been wobbling for ages... By wobbling do you mean you can move your wheel left to right? have you tried tightening the cones up? I don;t have sealed hubs but occasioanly the axle gets loos and it wobles, try tightening everything up before you go throwing your cash around... otherwise try ebay or google Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted May 13, 2006 Report Share Posted May 13, 2006 Knock out yer old bearings, take the bearings down to your local supplier, they'll read off the serial number and order you new ones. Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 13, 2006 Report Share Posted May 13, 2006 With those sort of hubs there's not a great deal to do, if it's the one I'm thinking of... The spacers outside aren't really worth a damn, but just make sure you tighten them up if they're loose, or just loosen them off and force them towards the hub body more.If you knock one of the bearings out, it'll possibly have a bearing ref. number on the seal itself, which would give you something to search for online from bearing suppliers Quote Link to comment Share on other sites More sharing options...
TheChai Posted May 13, 2006 Author Report Share Posted May 13, 2006 (edited) i have been to a supplier but had to get them specially ordered, 25 for a pair it was! i was wondering if any shops had them..thanks for the replies Edited May 13, 2006 by TheChai Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 13, 2006 Report Share Posted May 13, 2006 Are you after a front or rear hub's bearings? Quote Link to comment Share on other sites More sharing options...
shovel Posted May 13, 2006 Report Share Posted May 13, 2006 the bike shop where i work carry alot of hub bearings in stock, various sizes etc. as said above we normally compare the codes or knock out the bearings and compare side by side, could try your local bike shop, still expensive at 5 to 10 quid a bearing but by the sounds of it cheaper than a bearing supplier! Quote Link to comment Share on other sites More sharing options...
