David Posted May 13, 2006 Report Share Posted May 13, 2006 Hey, Ive got a few problems using flash MX. Ive added some buttons on top of a graphic and they are distorting it... Heres a screenshot of what I mean, its as if the button is wider then it is (Hard to explain) Any help much appreciated. The buttons I have added are GIF's from photoshop but I have the same problem with making a new standard rectangle button... Buttons in the pic are "Menu" and the next, previous and play symbols...Thanks,Dave Quote Link to comment Share on other sites More sharing options...
David Posted May 13, 2006 Author Report Share Posted May 13, 2006 Bump, its really annoying me now Tried loads of things and no luck! Its probably something simple... Quote Link to comment Share on other sites More sharing options...
Greetings Posted May 13, 2006 Report Share Posted May 13, 2006 I can't answer your question but it might be an idea to make the whole object in flash? Also, adding multiple flash elements to a page will reduce the performance significalntly.Hope that helps... Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted May 13, 2006 Report Share Posted May 13, 2006 Move them colser in so they don't stick out? See if resizing works? OR you could just make the scroll wheel thicker so they don't stick out. Quote Link to comment Share on other sites More sharing options...
David Posted May 13, 2006 Author Report Share Posted May 13, 2006 ManxTrialSpaz said: Move them colser in so they don't stick out? See if resizing works? OR you could just make the scroll wheel thicker so they don't stick out.Tried all that, the buttons arent too big at all, they dont stick out the grey area at all. Thats whats confusing me Quote Link to comment Share on other sites More sharing options...
MaXsteri Posted May 13, 2006 Report Share Posted May 13, 2006 Make the whole button/graphic in photoshop and make invisible buttons where you want them (make the shape for the button how you want it as normal and then put it somewhere stupid that isn't called in your actionscripting, like the over or hit state) Quote Link to comment Share on other sites More sharing options...
David Posted May 13, 2006 Author Report Share Posted May 13, 2006 MaXsteri said: Make the whole button/graphic in photoshop and make invisible buttons where you want them (make the shape for the button how you want it as normal and then put it somewhere stupid that isn't called in your actionscripting, like the over or hit state)Cheers! Quote Link to comment Share on other sites More sharing options...
David Posted May 13, 2006 Author Report Share Posted May 13, 2006 Ive fixed the problem using inivisble buttons but now I have another!!! When I add text exactly the same thing is happening Think I may have solved the problem using dynamic text now:) Quote Link to comment Share on other sites More sharing options...
Greetings Posted May 13, 2006 Report Share Posted May 13, 2006 (edited) I don't want to start another topic, if you're working in flash, you might be able to help me Excuse me for the OT. This is about action script. For instance I have in the document two objects: -movie clip a: - and in this movie clip 4 animations (movie clips) in 4 different frames -movie clip b: - and in this movie clip 4 buttons Now what I want to do, is when I click a button in movie clip b, for it to play an animation within movie clip a in the specified frame. So basically I want to make the "play" function work within a different movie clip and not the movie clip in which it is located. Frame labels don't work here Please help.... Edited May 13, 2006 by Inur Quote Link to comment Share on other sites More sharing options...
Danny Posted May 13, 2006 Report Share Posted May 13, 2006 I had this problem when creating my suduko game There are some compression settings when exporting i think its to do with those Quote Link to comment Share on other sites More sharing options...
