Hs33's
Ok I have had my t-pro for around a month and a half now and was wondering should I bleed my hs33's I bought the bike second hand and the person who had it before me said he hadn't ridden it in around 2 years should I bleed them or leave them as they are still powerful considering I rode a bmx with the old school u brakes before it and a mountain bike with some crap v brakes
Edited by chasthetrialsrider
You shouldn't need to bleed them, no. So long as they have been left alone they go for ages without needing a bleed. Magura mineral oil doesn't absorb water like 'Dot' brake fluid, so doesn't require bleeding as often.
I think it's every 5 years that magura reccomend you bleed them.
Alun
Squeeze the brake lever hard, and look to see if the cylinders flex outwards, apart from each other. If they do then the boosters to blame. Is it just on the bottom bolts? A four bolt booster will work better.
If not, then there might be air in the system, and then it will require bleeding. Theres bound to be some play though, more so if you have softer pads.
Alun
ok yes the cylinders are flexing out a lot so I am putting washers on them and tightning them up a lot
Don't bother, that won't make a difference. If theres flex, tightening will make no difference unless they where loose. I recommend a new booster, preferably four bolt.
Hope I've helped,
Alun
get a rb 1 off ebay brand new they cost about £15 which isnt bad also make sure your pads are close to your rim
to check if theres air in the brake pull you leaver very softly and keep pulling until you feel the leaver compress the oil if the leaver has to go in quite a distance before this happens i think a rebleed is in order (Y)
i wouldnt use blood mate, it makes the lever feel slow and yicky (tecnical term right there :P) bleed it with water, water isn't as thick as water so makes the brake feel much more solid.
Ben
You do realize you just said water isn't as think as water :P
But yeh bleed it with water, its much better and makes your brake feel far more responsive.
Thurston
I have just got an echo 4 bolt booster and my rear break is bleed with water its feels great. (Y) At the moment im running standard black blocks so i will be upgrading to some zoo or koox pads next mounth.
hope this hepled
joe
ok thanks but I am not to keen on bleeding with water as I have heard that it can effect the brake if it leaks my brakes don't leak but you never know also I have heard that you have to bleed them more often using water than you do with maggy blood maggy blood is I think to be bleed every 5 years or something
Sorry to be blunt but most of that is bullshit, you should bleed your magura every time it feels shit basically and the oil will prlly be like dust after five years. Water may cause some damage to seals "n" Stuff but my brake has been bled with water four 4 years and i have only had one burst hose
Magura hydraulic brakes do not need to be bled often at all if you're using their Royal Blood mineral oil, because it doesn't absorb water. Can't find it, but I'm sure it was around every 5 years that they recommend you bleed their brakes, unless they leak or anything.
From the magura website:
Mineral oil vs. DOT brake fluids
When it comes to the a/m advantages of a hydraulic brake system you have to consider mainly what sort of transmission medium is used in your brake, mineral oil or DOT brake fluid.
All MAGURA disc brakes have been a long time the only disc brakes which could be described as virtually maintenance free. The same information is of course also valid for the MAGURA rim brakes. With the exception of the regular pad wear check and a replacement in due time there is nothing to do for you as ALL our disc brake models feature since model year 2002 an automatic pad wear adjustment like the brake system of your car or your motorcycle.
The real asset, offered over years by MAGURA alone (and in the meantime copied by a Japanese company), is that our stoppers use low viscosity MAGURA Royal Blood mineral oil as transmission medium which does not absorb water and actually lubricates the whole system.
All other competitors' disc brakes use aggressive DOT brake fluid (used normally in car and motorcycle braking systems). DOT has to be changed regularly because it absorbs water, even the water vapor in the air inside your open system's brake reservoir. This has a negative effect on the brake's function. The bleeding of such brakes is then regularly necessary, but not funny at all. DOT is toxic, irritates your skin and strips the paint off your frame when you don't pay attention.
Do you really want to be bothered with problems like that? Choose the tricky, troublefree and clean solution: Rely on MAGURAs, if you prefer riding to wrenching. and remember for the case of the cases that MAGURA Royal Blood is much more bike oriented and nicer stuff to deal with. MAGURA brake technology. Simple solutions for smart bikers. Save the planet!
Right, to check if it needs bleeding the method given further up on pulling the lever slowly was kind of right but it's hard to feel whats happening in the brake if you've not got much of an idea on them like this guy comes across.
Pull the lever slowly but look at the pads, if theres a delay in the pads moving while the levers being pressed you'll need a re-bleed. With a good bleed the pads should move instantly.
I would also recommend bleeding with water as i'm sure most of the riders on here will say the same, it feels better and it doesn't cause any known damage to the brake. Yeah maybe after 6 years or so it'll cause a leak but by then you'll have had so much use out of it it'll have been well worth its money.
I've had mine bled with water for over a year now with no problems, just make sure you flush all the oil out when you first put the water in as you could be left with some nasty oily sludge that'll make the brake feel poor again. Have a search for topics on bleeding with water, there should be plenty and it's fairluy easy and best of all..... completely free.
