Deionized Water
think about it people, if you don't want air in your brakes then don't use water, unless it is de-ionised.
1. it will rot you seals
2. will rust it up good n proper
3. water is 1/3 oxygen!!!
But its a compound so that it still needs another oxygen atom to make it reactive! So if you dont have any air in your brakes then there's no harm!
Rob
I disagree, firstly like it matters if you have air in your system as long as the calipers return nicely and you have a nice feel to the brake, all is good. :)
Secondly i would pay good money to watch aliminium rust :mellow:
It could oxadise slightly though, which will do jack all :)
People do say that using water rots your seals, personally i think its a load of crap :P
Tom Booth has had hs brake bled with the same water for nearlly 2 years and i have for just over a year.
Neither of us nor all the other half of the trials polulation have had any trouble with seals rotting :)
cheers
what is deionized water and how can you make it. because aparently its good to bleed brakes with?
any help?
supposedly the stuff that comes out of the tumble dryer is deionised when its emptied
Edited by monty221pr
Yeh, Not sure about that one. I have heard that water thats melted from ice is deionised :S
Probably a mith i think. Just go and buy some :P or just bleed it with normal water. :D
cheers andy
