anzo Posted May 10, 2006 Report Share Posted May 10, 2006 Hi all,Righto, I have an onza intergrated headset, not that I have much choice, on my T-pro. This week I have fitted some Echo Teams, at the base of the forks it is a big 'square' shape, because this is big it rubs on the headset causing the steering to become very heavy occasionally.What I want to know is if I buy a intergrated Cane Creek headset for my pro, will it still rub? Reason for asking is I haven't seen the cane creek ones before and no idea what the fitting is like. Do you think I could use some sort of spacer (perhaps headset spacer) to seperate the forks from the headset? Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted May 10, 2006 Report Share Posted May 10, 2006 There should be a piece on the forks that matches the headset, a smallish metal rin about 1 1/7th '' wide, ave alook on your current forks, if it ain't there then buy the Cane Creek and remember to fit all the parts, then I don't see why it should'nt run smooth. Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 10, 2006 Report Share Posted May 10, 2006 If you've got the crown race on properly, there's no reason it should rub, pretty much. I know people have used the Teams with the Onza and Cane Creek headsets and have had no probs, so just check out you've got everything seated properly... Quote Link to comment Share on other sites More sharing options...
