KeNi Posted May 9, 2006 Report Share Posted May 9, 2006 I have recently broke my Hs33 lever and i was wondering if i use a Hs11 lever on it would it work? Quote Link to comment Share on other sites More sharing options...
the judge Posted May 9, 2006 Report Share Posted May 9, 2006 If you mean the whole lever then yes it would work but it wouldn't be very good. If you just mean the lever blade then I'm not sure if it would fit. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted May 9, 2006 Report Share Posted May 9, 2006 The whole lever would, but it'd be shit. - Plastic lever blade (I think) and no TPA. Quote Link to comment Share on other sites More sharing options...
_Owen. Posted May 9, 2006 Report Share Posted May 9, 2006 the hs11 lever will work but the piston is smaller so it will have less power, so it wont b quite as good. Quote Link to comment Share on other sites More sharing options...
Ali C Posted May 9, 2006 Report Share Posted May 9, 2006 its the opposite, the hs11 lever has a bigger piston which reduces the leverage and makes the brake weaker. Quote Link to comment Share on other sites More sharing options...
JT! Posted May 10, 2006 Report Share Posted May 10, 2006 and no TPA.hs 11's DO have tpa's. They're where the leave ajustment is on the hope mono trials. Better than the hs 33's TPAs.The only difference between the hs 11's and the hs 33's is the leaver, the rest of the brake is the same. So it would deffinatly work, and you would have a fully functional hs 11. You lucky devil you. Quote Link to comment Share on other sites More sharing options...
KeNi Posted May 10, 2006 Author Report Share Posted May 10, 2006 I have tried to put the lever on i did, i bled it then it wont work i have bled it a number of times, well it does work but incredible weak and it just feels like i got no brake the lever pulls in so it can touch the bars..Any suggestions? Quote Link to comment Share on other sites More sharing options...
JT! Posted May 10, 2006 Report Share Posted May 10, 2006 Did you undo the TPA fully befor you bled it? Quote Link to comment Share on other sites More sharing options...
KeNi Posted May 10, 2006 Author Report Share Posted May 10, 2006 Did you undo the TPA fully befor you bled it? Errrr....no Quote Link to comment Share on other sites More sharing options...
stetpro Posted May 10, 2006 Report Share Posted May 10, 2006 if u are putting the whole lever on then it will work as they are the same slaves, but i am not sure if changing the blade will work. Quote Link to comment Share on other sites More sharing options...
the judge Posted May 10, 2006 Report Share Posted May 10, 2006 Errrr....no Well you should have, undo it fully and try bleeding it again Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted May 10, 2006 Report Share Posted May 10, 2006 Any suggestions?Did you undo the TPA fully befor you bled it?Errrr....no Made me laugh Don't worry, happens to everyone once in a while Quote Link to comment Share on other sites More sharing options...
