mark145 Posted May 9, 2006 Report Share Posted May 9, 2006 Righty o' then i bought a new brake from halfords ( I know a mistake) for my everyday bike because one of the arms had snapped on the others. How do u set them up i have done it all as told but when i pull the leaver it comes straight to the bars, i have checked the cables they were new any way with the brakes so they are fine. I just can't figure out what is wrong with them i need help or i will have to pay to get them fixed and i need the money for something else. Quote Link to comment Share on other sites More sharing options...
Simpson Posted May 9, 2006 Report Share Posted May 9, 2006 Hey kids,Just thought i'd post up a how to for setting up v type brakes. Hope it helps a few people that still use them like me.enjoy The standard for mountain bike brakes is: your brakes should be able to stop your bike within 15 feet while a 150-pound rider is going 15 mph. (And they shouldn't screech or wobble.)Optimum brake performance also depends on undamaged rims and a true tire alignment (perfectly round rim with no lateral warpage) -- you may need to replace or true your rims to get your brakes working right. This section describes a basic tuneup and cleaning. Please see other sections for brake pad replacement or truing of rims.If your brake cables have dirt in the housing, the brakes may be hard to pull, or the calipers may not rebound away from the tire when you let off the brakes.Clean all visible brake parts with a brush. Soapy water works fine. If there's substantial oil or grease buildup, use a degreasing solution.Release the brake cable by detaching the retaining clip from the cable housing.**Detaching the brake cable from a V-brake system** Coil-spring brakes may be more susceptible to gumming than those with an external spring. To remove the caliper for cleaning, first release the spring tension by backing out the tensioning screws on each side.Loosen the tensioning screw to relax the spring before removing the calipers. Now unscrew the mounting bolt to remove the caliper. Clean the spring and bushing thoroughly. Relube and remount the calipers. Don't get grease on the rim or tire!Removing the caliper to clean the swivel and spring. Check the brake pad for wear. A ridge of unworn pad on top or bottom means your brake isn't hitting the rim squarely. Replace worn-down or unevenly worn pads.Inspecting the brake pad. Check the rim for damage. If you do much mud-riding, the rim may wear thin. As the brakes push in, the metal curves inward. Cracked or buckled rims need replacement.If there are local rock-bites on the rim, smooth the ridges off with ultra-fine sandpaper. If the rim is widely rough, clean and smooth the rim with steel wool.Now reattach the brake cable to begin aligning the brake pads.**Reattaching the brake cable** Go to the brake lever. Turn the adjusting knob back, leaving only about 1/8" of space between the knob and the lever housing.Backing off the cable length adjuster. Loosen the cable retaining screw on the caliper. Take up extra cable until each brake pad is about 1/8" from the rim, then tighten the retaining screw. Loosen the stem of the brake pad. On V-brakes, this is done with the nut at the end of the stem.**Adjusting the cable length** Slide the stem of the brake pad up or down within the slot in the caliper, until it's exactly perpendicular to the plane of the rim as the pad touches. Turn the pad so it's aligned along the center of the rim along its entire length. Tighten very slightly.Toe the brake in slightly at the front end. This means the FRONT end of the brake pad will be a trace closer to the rim than the back end. (Screeching brakes are fixed by toeing the brake pad.) Put a couple of business cards under the back end of the pad, then grip the brake lever to tighten the pad down against the rim. Now tighten the stem fully.**Positioning the stem (push-arm) and brake pad** Using the tensioning screw, add rebound to the calipers until they spring away from the rim strongly. Rotate the tire, while watching the position of the pads in relation to the rim. If the rim is not true, both brake pads may hit the rim at different times as the tire rotates. If so, you need to true the rim before proceeding.**Checking clearance. Checking stem and brake pad alignment** Grasp the brake lever and stop the rotating tire several times. Check the position of the pads relative to the rim. If one is closer (or rubbing), tighten its tensioning screw (turn the screw IN) so the caliper rebounds further away from the rim. Repeat adjustments of 1/4 turn until the pads remain equally spaced.Adjusting the spring tension. Tighten the brake cable with the adjusting nut at the brake lever. Goals: (1) The pads shouldn't hit the rim. (2) As you pull the lever, the brakes should engage at a point that's comfortable for your hand. (3) You should have around 1-1/2 inches of daylight between the lever and the handlebar when you're pulling hard on the brake. Some riders like a closer grip, leaving only about 1/2," but this puts you at risk of "bottoming out" the lever with the brake only partly engaged.**Fine adjustment of cable length** If you ride in mud, you may need extra room between the pads and the rim. Loosen the cable slightly. Be sure you still have plenty of space left between the lever and handlebar, so you'll retain braking power as the pads wear down.**Checking brake lever position** If your fingers are short, or you like the levers a bit closer to your hand, you can adjust the lever's starting position. The adjustment screw opposite the lever can be used to swing the lever back towards the handlebar. (This gives you less total brake-lever motion, so the tuning of the brakes needs to be more exact.)And there you go, hope you have enjoyed this and most importantly i hope it taught you one or two things too.cheers,jakeobiously not too hard ...no im just good lol Quote Link to comment Share on other sites More sharing options...
streethusslin Posted May 9, 2006 Report Share Posted May 9, 2006 lol Quote Link to comment Share on other sites More sharing options...
mat hudson Posted May 9, 2006 Report Share Posted May 9, 2006 pull more cable through at the v brake arm. Quote Link to comment Share on other sites More sharing options...
Lee Cable Posted May 10, 2006 Report Share Posted May 10, 2006 If the pads are to far away, you could pull more cable through, and put some random spacers in between your pad and the v brake arm, that always helps! Quote Link to comment Share on other sites More sharing options...
wilko Posted May 13, 2006 Report Share Posted May 13, 2006 RADICAL RIDER TOOK THE WORDS OUT OF MY MOUTH Quote Link to comment Share on other sites More sharing options...
Connor Posted May 13, 2006 Report Share Posted May 13, 2006 use the screw on what i think is called the noodle Quote Link to comment Share on other sites More sharing options...
mark145 Posted May 13, 2006 Author Report Share Posted May 13, 2006 All sorted now it was an easy fix the cable was jammed in the outer casing so when i pulled it, it didnt do anything. I am very happy with this considering many people say halfords is rubbish Quote Link to comment Share on other sites More sharing options...
