Brakepads, Which Way Around ?
duane
Hi,
I have some V Brake pads with an offset mounting stud, I assume there is a good reason why the mounting is off center, so my question is should I install the pads with the longer end point along or opposite to the direction of wheel rotation ?
Along opposite
wheel rotation
Thanks
Duane.
Years ago I had a set off Koolstop canti (!) pads that worked better when you reversed the direction...
Try both.
Oh and if it's got one of those toe-in bits that kinda angles in a bit compared to the rest of the pad, file it off.
