Maguras On V-brake Mounts
stetpro
HS11's have pretty rubbish levers to be honest.
2 Bolts mounts are perfectly fine to run maguras on they are just a little trickier to setup thats all.
If he wants to upgrade his brake he could get a HS33 lever (the slaves are the same on a HS11) and some aftermarket pads.
my m8 has hs11's and der crap just wundering if its because der fitted on v-brake mounts or if its the hs11's??
ste
You can buy vee Brake adaptors from a local shop shouldent be too expensive just screw them on to the vee mounts and attach the magura to it and it should be sound then. (Y)
Regards
Dave
surley if there on v brake mounts they won't be as powerful because it will flex more therefore less power.
hs33 levers are much better because of the shape it allows you to put more power on the brake. also the master cylinders are not as powerful, on the 11, probably cause theremade of plastic. :D
lee
Edited by lee220
