Where To Get Hope Hose?
Ben Cox
I would be supprised if you could not get hope hosing from hope.
But any hope dealer should be able to get hold of some for you. Just check a few shops CRC deffo sell it, I reccon tarty could get hold of it as they sell hope don't they ?
Edited by Swize
have got plenty at the shop i work at, and i have spare fittings and stuff aswell.
are you using it for a disc? or a magura?
i would advise use it for a front disc BUT not for rear magura only the crossover pipe (Y) iv heard that the "inner" diameter is quite small therefore the oil doesnt work too well with it. the main problem with HS33 etc is the crossover pipe.
Waynio.......................
have got the "universal" fit kits. PM me or something i will give you prices and stuff. and let you know what bits and pieces you would need. to say make a crossover pipe and front hose etc etc
im using it on a rear mono trials, its split right up by the lever, how much would it cost to either replace the hose and give it a bleed or maybe cut out the split bit then put the doodah bits back on n bleed it :)
Ben
Hope bits are reusable. Just take your wheel out and pump the lever so the pads meet, then get an 8mm spanner and undo the compression nut at the lever.
Take the olive and stuff off in order, cut the hose, put it all back together then push the pistons back in and all the air from the top will be pushed out through the master cylinder when you push the pistons in.
so you already have the "braided" hose on it????
if so just undo the 8mm spanner on the end, pull the brass "plug" out, take off the olive, trim down to where you need it then re-connect the olive and the brass plug and you will get it (Y) if you need any help you can always bell me on 01535 610839 ask to speak to Wayne and i will run through it with you. you need to dom something to the olive to make it reconnect "easier" but its too hard to explain what to do.
Waynio..........................
you can deffo re-use the one you have
