SCOTTY___ Posted May 4, 2006 Report Share Posted May 4, 2006 RighteoooooI'm running Monty ISIS 158mm Cranks with an ACS Claws freewheel with an Echo 7075 BashRing (Silver One) and I'm getting a new BB but I'm not 100% certain what lenth i will need.I'm certain it will be a 68x ????. So will the Koxx BB in 68x127mm fit? Plenty of room? Or will i need 2 grind the ACS removal pawls off?Its an Aorta frame.Thanks in advance.Scotty! Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted May 4, 2006 Report Share Posted May 4, 2006 a 127 will be pretty safe i reckon, genrally you do need a bloody wide bb for ffw and a bash Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted May 4, 2006 Report Share Posted May 4, 2006 no idea....but personally...i've always had to grind the tabs off...and i've had megamo +squareonza +squaretensile + isis..adam Quote Link to comment Share on other sites More sharing options...
Guest Posted May 4, 2006 Report Share Posted May 4, 2006 On my monty im running 12mm7 and it got loads of space there, I could probobly run two freewheels up front in the space. Quote Link to comment Share on other sites More sharing options...
joe b Posted May 4, 2006 Report Share Posted May 4, 2006 Yeah, Craig, you will definately be safe and sound with a 127mm length BB. Should be enough clearance there for you. Did you swap frames with Christof? If you did, then hope you like it... Cheers,Joe. Quote Link to comment Share on other sites More sharing options...
