mr manx man Posted May 2, 2006 Report Share Posted May 2, 2006 i have just recently started to do gaps including dropgaps does anyone have any advice for me to take in like, whats the best way to get airhow do you get distancehow do you land properlywhen do you hope from what your hopping from and is it better to go from static or rollingas i realy do suck at gapping i never seem to be able to gap far so any advice would be great Quote Link to comment Share on other sites More sharing options...
Adam t Posted May 2, 2006 Report Share Posted May 2, 2006 when i gap just before i do the final kick i lower my front end a bit then kick as hard as possible, also i find it easeir to gap when i sort of flick my back end around if you get what i mean :$ anyways hope that helped Quote Link to comment Share on other sites More sharing options...
Ross Gardner Posted May 2, 2006 Report Share Posted May 2, 2006 (edited) With gapping, i get to the very edge of the ledge, pallet, then i lower my front and kick harder than i normaly would do with a kickhop. With bigger gaps, i try to kick harder(make sure your chain is tight because if it was loose your kick would not be as powerful and your chain could come off and you would look silly!) and turn slightly to help me land on the pallet more comfortably and easily Edited May 2, 2006 by gawk Quote Link to comment Share on other sites More sharing options...
zoo Posted May 2, 2006 Report Share Posted May 2, 2006 Before i take off for a big gap (7 foot,its big to me) i lower the front end..but it runs pretty much parallel to the floor so that i get lots of leverage from the bars and give the pedals a good hard kick,other than that you have to develop your own technique over time,hope its helped a little mate,good luck zoo baby! Quote Link to comment Share on other sites More sharing options...
bikerboy16 Posted May 2, 2006 Report Share Posted May 2, 2006 i fined the best way to gap is to have a bit of a rolling start do a hop to the back wheel and let your front wheel drop and try to keep all your momentum going and then do a really hard kick on the pedals (HELPS IF YOU HAVE A GOOD HUB WITH A LOT OF ENGAGEMENTS AND A TIGHT AND STRONG CHAIN) and to get extra distance try to tuck up get you that extra little bit further. my best is around 8ft but it takes a lot of practise so keep at it Quote Link to comment Share on other sites More sharing options...
Mr_Pitbull Posted May 2, 2006 Report Share Posted May 2, 2006 Use your legs like pistons, kick like f**k! End of. Quote Link to comment Share on other sites More sharing options...
Token Posted May 2, 2006 Report Share Posted May 2, 2006 (edited) ow I've only just started to try an master the art of gappin, but at the mo I find it alot easier to do rolling gap I cant seem to get the air after dropping the front wheel from static Edited May 2, 2006 by Scopse Quote Link to comment Share on other sites More sharing options...
carnagr Posted May 3, 2006 Report Share Posted May 3, 2006 Jump? Quote Link to comment Share on other sites More sharing options...
Ra964 Posted May 3, 2006 Report Share Posted May 3, 2006 i just lower the front alot when i want to gap more (i gap like 2m), and kick hard, also in the air i pull the bike up like mad, folding the knees Quote Link to comment Share on other sites More sharing options...
knappers !!! Posted May 3, 2006 Report Share Posted May 3, 2006 (edited) iff your doing big statics turn slightly in mid air by kicking your bum and legs out and you'll get further and dont forget that wiggle !!!!!!!!! Edited May 3, 2006 by knappers !!! Quote Link to comment Share on other sites More sharing options...
TomN Posted May 3, 2006 Report Share Posted May 3, 2006 Lower front as low as you can like then give it a great big pasty kick, tuck your knees so your comes up and go up as well then stretch legs out for landing and bend when your wheel touches thee other side Quote Link to comment Share on other sites More sharing options...
