josh p Posted May 1, 2006 Report Share Posted May 1, 2006 Hi im pissed offi have just come back from a ride, to find i have a crack on the stay.Has anyone had this problem with there t-lite?What do you think i should do,weld it up or new frame and if so what one. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted May 1, 2006 Report Share Posted May 1, 2006 haha, get a zona, welding is shit. Quote Link to comment Share on other sites More sharing options...
onzatprodude Posted May 1, 2006 Report Share Posted May 1, 2006 (edited) get a monty pr look awesome imo. you are never guaranteed that the welding will hold up so eventually you will proberblys need a new frame Edited May 1, 2006 by onzatprodude Quote Link to comment Share on other sites More sharing options...
TomN Posted May 1, 2006 Report Share Posted May 1, 2006 Get a new frame it'll be better. Get ermmm either, Echo/ZOO, Monty, or a Iolo mod Quote Link to comment Share on other sites More sharing options...
bikerboy16 Posted May 1, 2006 Report Share Posted May 1, 2006 have you still got warranty on it cause that should cover it hope this helps Quote Link to comment Share on other sites More sharing options...
King C Posted May 1, 2006 Report Share Posted May 1, 2006 Is the crack bad? If its not too bad(ie. a hair line crack) then mark it where it stops and see if it gets any bigger. If it gets alot worse then buy a new frame. If not then keep riding it unless you want a new frame Quote Link to comment Share on other sites More sharing options...
JT! Posted May 1, 2006 Report Share Posted May 1, 2006 Has anyone had this problem with there t-lite?No. Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted May 1, 2006 Report Share Posted May 1, 2006 No. second..ed Quote Link to comment Share on other sites More sharing options...
Jaffacakes Posted May 1, 2006 Report Share Posted May 1, 2006 No. Third..ed Quote Link to comment Share on other sites More sharing options...
anzo Posted May 2, 2006 Report Share Posted May 2, 2006 Get a new frame it'll be better. Get ermmm either, Echo/ZOO, Monty, or a Iolo mod I'm going to start to have to track IP addresses down and start removing certain individuals from this world. Sorry, I'm just sick of opening a topic hoping for something decent to reply to and there is just 'get a GU' or something like that, stick some more information to it! Why get a Zoo? Or a Monty? Hes not going to read your reply and go 'ok then' and get his credit card out.Sigh...anyway. Before anyone bites my head off, I have a knife, so don't even try it.In reply to the lads topic.If you know a welder, by all means get it done. It won't last forever, but it'll cover your back whilst you save up for a new frame.As its cracked, the frame material surrounding the crack will have some heavy fatigue, and it'll be prone to cracking/snapping again after a short time, especially after welding as the heat will cause the frame to weaken further. So a new frame is the long term solution.If its possible, you could get some aluminium plating, and 'patch' over the crack, this will probably make it survive a bit longer, but I'm not sure if it'll be completely 'doable'.Note that I said 'If you know a welder'. They'll probably do it for free, otherwise if you take it to a welding specialist, you might get a better job done, but it'll cost you, not much, I'd guess about 20 quid to make it worth his while, maybe 30 quid for the plating option. Quote Link to comment Share on other sites More sharing options...
MikeCottTrials Posted May 2, 2006 Report Share Posted May 2, 2006 If i where you i would get yourself a zoo python or a GU typhoon, they both look super lush plus im thinking of getting one of their big brothers Quote Link to comment Share on other sites More sharing options...
ogre Posted May 2, 2006 Report Share Posted May 2, 2006 I'm going to start to have to track IP addresses down and start removing certain individuals from this world. Sorry, I'm just sick of opening a topic hoping for something decent to reply to and there is just 'get a GU' or something like that, stick some more information to it! Why get a Zoo? Or a Monty? Hes not going to read your reply and go 'ok then' and get his credit card out.Sigh...anyway. Before anyone bites my head off, I have a knife, so don't even try it.If i where you i would get yourself a zoo python or a GU typhoon, they both look super lush plus im thinking of getting one of their big brothers Quote Link to comment Share on other sites More sharing options...
