kev kazama Posted April 30, 2006 Report Share Posted April 30, 2006 Hey guys Just been out, and my back mag hs33 got a little sloppy. i tried to adjust it but the twisty adjust is solid !!! it wont move either way Has anyone else had this and do you know how 2 free it up?? Quote Link to comment Share on other sites More sharing options...
basher Posted April 30, 2006 Report Share Posted April 30, 2006 chances are its cross threaded so ur best hope of gettin it free spray loads of oil on and leave it for a bit. u can also try useing a screw driver and use the groves in the tpa to push it round. its just a case of keep tring but the screw driver way usually works. Quote Link to comment Share on other sites More sharing options...
God-Rides-Trials Posted April 30, 2006 Report Share Posted April 30, 2006 Hello, i had the exact same thing happen to me so i just took apart the lever and then used a pair of pliers and put it all back together and it works like a dream but takes ages and make sure you remember where it all goes. Cheers, Andy Quote Link to comment Share on other sites More sharing options...
kev kazama Posted May 1, 2006 Author Report Share Posted May 1, 2006 cheers guys, ill give the screwy a go, if that fails ill take it apart Quote Link to comment Share on other sites More sharing options...
