bbt Posted April 29, 2006 Report Share Posted April 29, 2006 All becoz i put tar on my break i got hurt, perfectly fine backhopping on a 5 foot drop.....got to the end and back break locks up and go flying shoulder first into the ground. Pretty hurt and in lots of pain. so basically because of tar i broke my collar bone!!!!!! puts me out of riding for 6 week min. Quote Link to comment Share on other sites More sharing options...
fredrico Posted April 29, 2006 Report Share Posted April 29, 2006 Simple solution get a grind Quote Link to comment Share on other sites More sharing options...
bikerboy16 Posted April 29, 2006 Report Share Posted April 29, 2006 don't use so much tar and it won t stick then but i know what u mean i ve had some close call when my back wheel has locked up at the wrong time Quote Link to comment Share on other sites More sharing options...
Mr_Pitbull Posted April 29, 2006 Report Share Posted April 29, 2006 Learn to set brakes up. Quote Link to comment Share on other sites More sharing options...
JT! Posted April 29, 2006 Report Share Posted April 29, 2006 I bet you used koolstops with a shag load of tar. Quote Link to comment Share on other sites More sharing options...
Clarky Posted April 30, 2006 Report Share Posted April 30, 2006 unluky get well soon, but FOR THE LOVE OF GOD GET A GRIND AND DECENT PADS IT IF DEATH UPON YOU USING TAR.../Clarky lol Quote Link to comment Share on other sites More sharing options...
will17will17 Posted April 30, 2006 Report Share Posted April 30, 2006 Try a grind, setting your brakes up properly, new pads or not so much tar , DON'T PAINT YOUR RIM! Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted April 30, 2006 Report Share Posted April 30, 2006 Tar rules until it gets wet. in the summer its mint. but your not supposed to paint your rims with it. just do little very fine scratches. works much better. Not saying I use tar or anything Quote Link to comment Share on other sites More sharing options...
Mr_Pitbull Posted April 30, 2006 Report Share Posted April 30, 2006 Only sucks when wet because its oil based......hense when added to a slight bit of water gives an oily effect to the tar. Quote Link to comment Share on other sites More sharing options...
' Mart ' Posted April 30, 2006 Report Share Posted April 30, 2006 i use koolstop's and tar and it brilliant only scratch the rim lightly then ride holding ur brake slightlytill it feels right dnt just put it on and try a drop lol Quote Link to comment Share on other sites More sharing options...
roby James124 Posted April 30, 2006 Report Share Posted April 30, 2006 Hi tar is excellent when you put the right amount of it on but a grind is still a lot better. Rob Quote Link to comment Share on other sites More sharing options...
ramps Posted May 1, 2006 Report Share Posted May 1, 2006 I bet you used koolstops with a shag load of tar. You would be nearly correct, he is actually on maggie blacks. However, when using tar I found every month or so taking the back wheel off and giving it a good doing over with a wire brush to get ride off the old shitty tar works a treat. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted May 1, 2006 Report Share Posted May 1, 2006 I bet you used koolstops with a shag load of tar. I did It worked well cos I never put too much on *ahem*My mate used to cover the entire rim with tar, so it was completely black, with a booster + koolstops. Ofcourse his brake rarely unlocked... Quote Link to comment Share on other sites More sharing options...
mark145 Posted May 1, 2006 Report Share Posted May 1, 2006 You would be nearly correct, he is actually on maggie blacks. However, when using tar I found every month or so taking the back wheel off and giving it a good doing over with a wire brush to get ride off the old shitty tar works a treat. I bet that has a great effect before you put the tar back on. Just think that is giving a bit of a grinding effect . Quote Link to comment Share on other sites More sharing options...
mtbjosh Posted May 2, 2006 Report Share Posted May 2, 2006 well when i passed you that very day i actually said, 'hey up luke, ull hurt yourself with that brake' and voilla so you did. You could have at least wire brushed your rim at some stage, and it wasnt a 5foot drop, sheesh it was about 3.5foot tops!! As adam can backwheel that wall everytime all the time he cant backwheel and sidehop 5foot i can tell you that. Quote Link to comment Share on other sites More sharing options...
boris_on_trials Posted May 2, 2006 Report Share Posted May 2, 2006 Tar is awsome i only use a little bit but i hate it when a little bit brakes off and ypu dont see it then gets squashed into the rim thats well annoying and plus when it gets wet and melts all over your floor Quote Link to comment Share on other sites More sharing options...
knappers !!! Posted May 3, 2006 Report Share Posted May 3, 2006 brake set-up , plazmatics , grind,all you need m8 Quote Link to comment Share on other sites More sharing options...
coolbeen Posted May 3, 2006 Report Share Posted May 3, 2006 I use tar on a rim with no grind but only a bit with the brake set up good just to make sure that it is going to work. I have a grind on one of my bikes and it is so much better then tar it stops up just like that but does not lock up like tar. Quote Link to comment Share on other sites More sharing options...
