flipkickbs Posted April 27, 2006 Report Share Posted April 27, 2006 I've just replaced my old KMC chain with a new KMC Kool bmx, and am now getting chain suck really badly. From what a few people have said, i'm getting that its the old chainring causing this as it was previously bed into my old chain. So is it just a simple case of replacing the chainring to get rid of this chain suck? Any help muchos appreciated Ian Quote Link to comment Share on other sites More sharing options...
CBProductions Posted April 27, 2006 Report Share Posted April 27, 2006 (edited) Normally mechanical standards say to replace all parts of the drive at once ( i.e gears , chains, rings) to avoid above mentioned problems , have a look at the ring for any mishapes. Is it old ? Edited April 27, 2006 by CBProductions Quote Link to comment Share on other sites More sharing options...
JT! Posted April 27, 2006 Report Share Posted April 27, 2006 What the hell's chain suck? Quote Link to comment Share on other sites More sharing options...
TheMunn Posted April 27, 2006 Report Share Posted April 27, 2006 What the hell's chain suck?Don't worry you pretty little wheeled bike JT. If you reeeeally want to know, msn me. And yeah, depending on your rear sprocket you would need to replace the chain ring aswell. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted April 27, 2006 Report Share Posted April 27, 2006 could just try and ride it and see if it wears in, its happened got any pics of the sprocket/chainring so we can see how worn they are? if the teeth are hooked/spiked they are gone new drivetrain time Quote Link to comment Share on other sites More sharing options...
flipkickbs Posted April 27, 2006 Author Report Share Posted April 27, 2006 Well my chainring was bad enough that i had to file off ridged edges from almost all the teeth. So i'm guessing new drivetrain would do the trick. But then again, my rear sprocket is near on perfect, so hopefully that can stay on. Ian Quote Link to comment Share on other sites More sharing options...
TheMunn Posted April 28, 2006 Report Share Posted April 28, 2006 Yeah, i've found that single speed sprockets last a long ol' time. If your filing burrs off the ring then it will need replacing for sure. Quote Link to comment Share on other sites More sharing options...
flipkickbs Posted April 28, 2006 Author Report Share Posted April 28, 2006 Well hopefully that will sort out the whole thing then I'll have to find a 20/ 22t chainring in a bikes shop tomorrow though Ian Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted April 28, 2006 Report Share Posted April 28, 2006 Tarty it, Middleburn jobbie, could even ask for next day garenteed and it will be here for the 3 day weekend. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted April 28, 2006 Report Share Posted April 28, 2006 i got chainsuck so i increased the tension on my rear mech, then i got a rholofdasldjklsd. both worked well. Quote Link to comment Share on other sites More sharing options...
