MasterOfGussets Posted April 26, 2006 Report Share Posted April 26, 2006 Hello,I used to do a lot of riding back around '99/'00 (mid-teen years). I started to get into trials back then but had a hell of a time trying to get hold of parts. It seems a lot easier to get parts now and i'm earning money to fund the hobby.I was looking at building around either the GU Typhoon (stock) or Zoo! Pitbull frames until I saw the amount of reviews commenting on bad quality. So I'm starting to look at the Toxin Two frame. Mainly because it's got a more "newbie-friendly" (?) geometry. But I can't seem to find any information on the BB shell size, headtube diameter, tyre clearance, etc.I would have guessed it's a 1 1/8" headtube and a 68mm shell. But I don't want to assume and buy parts that aren't going to fit.If anyone could suggest a better frame choice I'm somewhere around the 5'11"-6'.Thanks in advance for any help. Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted April 26, 2006 Report Share Posted April 26, 2006 yes the vast majority of trials bikes have 1 1/8" forks but I can't suggest a frame for you as I r mod rider I think the toxsin is quite nice though and a good choice Quote Link to comment Share on other sites More sharing options...
MasterOfGussets Posted April 26, 2006 Author Report Share Posted April 26, 2006 Thanks for the reply.I had been thinking it was standard because of the extra strength in oversized tubing (if I understand it correctly?!)Also, I'm hoping to put in a set of Onza Tuf Guy's (if sizes allow). But I can't find any information on the disc mountings on them and I would like to run a Hope Mono Trials disc on the front.Another frame I'd been looking at was the Echo Control. I would consider the Toxsin One, too, if anyone knows of a shop I can get them in? (Tartybikes only have the 'Two'). Quote Link to comment Share on other sites More sharing options...
the judge Posted April 26, 2006 Report Share Posted April 26, 2006 I think Mersey Trial would be able to get you a Toxsin One. I have an 05 Echo Control and it rides really well. You could run a Hope Trial disc on those forks + they are 1 1/8" so they would fit in the frame too Quote Link to comment Share on other sites More sharing options...
