Wireless Internet. Problem 2.
Dan6061
So 2 days ago, it's all working good.
Router in my room, PS2 connected to it via Ethernet cable.
Wireless adaptor in my PC in my room (too shit for a LAN port) and another adaptor in the computer downstairs.
Somehow the DSL cable from the telephone line, to the router came out.
After a lot of playing about with the Router settings etc, I noticed it was out. :$
All the settings to everything was the same as before, and it doesn't work.
At the moment I've got the router downstairs, plugged in through an Ethernet cable.
The Wireless adaptor connected to my PC upstairs can't connect to the network.
If it's any help, it's a Netgear router I got from PC World. - Is that my problem? :P
I tried re-installing the adaptor, systom restore to a frew days ago when it was all working.
No luck. :(
What's up with it now?
Is it your router not working or is it your adapter?
If its your router, reset it. By pushing a little pin into the tiny hole, and resetting it. All you will need todo is to re-set it up and that'll be fine. your adapter should be fine?
Try that and let me know.
From Lee
