onzatprodude Posted April 23, 2006 Report Share Posted April 23, 2006 hi, i've just recently been able to bunny hop up objects, but when i do my highest, which really isn't very big my wheel is hitting it on the corner. i also find manuels really hard because its nearly impossible to pull my front end up! i'm currently running brisa bars + stem and koxx forks which are low (mod).i was just wondering could you suggest anything that will help me?have you got any tips? is there anything you think i should change?thanks Quote Link to comment Share on other sites More sharing options...
Ben Cox Posted April 23, 2006 Report Share Posted April 23, 2006 hitting the front as you pull up?if so, get more speed and pull up earlier, i had to learn this as i get higher, i now pull up earlier and my front never touches and i make it most of the time ben Quote Link to comment Share on other sites More sharing options...
King C Posted April 23, 2006 Report Share Posted April 23, 2006 onzatprodude said: i'm currently running brisa bars + stem and koxx forks which are low (mod).thanks Do you mean your running a stock stem on a mod? If so get a mod stem. That'll probably help. Also with manuals I find that it helps if you point your feet up instead of parallel to the ground. Quote Link to comment Share on other sites More sharing options...
yoyoyo Posted April 23, 2006 Report Share Posted April 23, 2006 Get shorter bars and stem, generally helps with pulling up the front end. Quote Link to comment Share on other sites More sharing options...
onzatprodude Posted April 23, 2006 Author Report Share Posted April 23, 2006 no ive got a mod stem on a mod bike but i was wondering if i should get a shorter stem or a lower one? Quote Link to comment Share on other sites More sharing options...
Ben Cox Posted April 23, 2006 Report Share Posted April 23, 2006 noo dont get a lower stem, will make getting the front up even harder, get an echo team stem with some zoo riser bars, thats a nice combination for bunnyhopsBen Quote Link to comment Share on other sites More sharing options...
onzatprodude Posted April 23, 2006 Author Report Share Posted April 23, 2006 yoyoyo said: Get shorter bars and stem, generally helps with pulling up the front end.you got any suggestions on stem? Quote Link to comment Share on other sites More sharing options...
yoyoyo Posted April 23, 2006 Report Share Posted April 23, 2006 I don't about short stems any more but i remember changing to wide bars and long stem and i can't lift as high or easy any more. But it means better balance. Quote Link to comment Share on other sites More sharing options...
Trials Boy Posted April 23, 2006 Report Share Posted April 23, 2006 Go up to the obstical at a fair ammount of speed, pull up at the last minute making sure you don't hit it with your front wheel bend your arms, lift the backend up and bend your legs making sure your body is as low to the bike as possible and the bike is as high as you can pull it. Learnt it on my BMX. Quote Link to comment Share on other sites More sharing options...
Mark W Posted April 23, 2006 Report Share Posted April 23, 2006 Lower makes it harder to pull up, which isn't so good.With mods, you have to reaaaaaaaaaally exagerate lifting the front end up. You have to pump really hard, and just yank it back far more than you'd think you would do. If you're landing to back wheel, it doesn't matter so much if you over-do it 'cos you can just plant the back wheel on and hey-ho, you're sorted.This is a vid from when God was a boy (literally that long ago Think it must be 2 years or so now 'cos I'm on a T-Pro, and that's Sikamon Simon saying 'nice one', and he's been being raped by navy boys for the last year and a bit I think...), but it shows you the technique I guess.LinkEDIT: I did that on that T-Pro, which was a 1000mm WB and had pretty high bars. I can still do that now though on my Zip, which is 1045 and has a pretty low front end ('cept for the T-Master stem ), so if you've got the technique you can do it on most bikes, so don't bother splashing out on new stuff just for hops or whatever, just adapt to what you have Quote Link to comment Share on other sites More sharing options...
chris mac Posted April 23, 2006 Report Share Posted April 23, 2006 hello, flat bars make it realy hard to bunny hop thats why i dont run them, not that i can afford to change them see if one of your mates has eny old risers going for cheap Quote Link to comment Share on other sites More sharing options...
