Trials mama Posted April 22, 2006 Report Share Posted April 22, 2006 hey guys, i built up my monty the other day, and the freewheel rubbed a lil bit on the bb (set up, fsa 128 i think, acs and zoo bash on zoo cranks) now this didnt cause a problem on my t-pro, but on the monty it has eat away at my bb, the tool only just fits in now. To add to this my lbs cant get my freewheel off with out destroying it, as i want to remove the bash for more clearence.i can get pics if needed.i dont no what to do, i was gonig to wait for the tensile freewheel then demolish my acs, but has any one else got any sensible ideas?cheers guys eddie Quote Link to comment Share on other sites More sharing options...
Shaun H Posted April 22, 2006 Report Share Posted April 22, 2006 I'm guessing you mean the removal tabs on the freewheel are hitting it when you pedal right?If so the only option really is to carefully grind these off. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted April 22, 2006 Report Share Posted April 22, 2006 then destroy your freewheel whenb it needs removing!! Quote Link to comment Share on other sites More sharing options...
TomN Posted April 22, 2006 Report Share Posted April 22, 2006 More reasons why thee Tensile freewheel needs to be out soon. Quote Link to comment Share on other sites More sharing options...
Trials mama Posted April 22, 2006 Author Report Share Posted April 22, 2006 yea sounds good, i was going to grind the tabs off but the thing is would that make the freewheel a bitch to get off when i get the tensile one?? Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted April 22, 2006 Report Share Posted April 22, 2006 yea sounds good, i was going to grind the tabs off but the thing is would that make the freewheel a bitch to get off when i get the tensile one??Not if you have to brake it off anyway, you could grind it, or get some grips or something, I'm sure your LBS will manage.Mat Quote Link to comment Share on other sites More sharing options...
Janson Posted April 22, 2006 Report Share Posted April 22, 2006 I've used a little spacer on my driveside isis crank for ages, for the freewheel to not rub on the bb shell.i am not sure if i use one or not atm, but i run a fixed sprocket now. Quote Link to comment Share on other sites More sharing options...
Trials mama Posted April 22, 2006 Author Report Share Posted April 22, 2006 I've used a little spacer on my driveside isis crank for ages, for the freewheel to not rub on the bb shell.i am not sure if i use one or not atm, but i run a fixed sprocket now.i thought about that but i doubt i can get my bb out now, as the freewheel has eat away so much at it Quote Link to comment Share on other sites More sharing options...
Janson Posted April 22, 2006 Report Share Posted April 22, 2006 is there anything wrong with the BB though?I'm talking about a spacer on the axle, a spacer between the bb and frame wouldn't help. Quote Link to comment Share on other sites More sharing options...
Trials mama Posted April 22, 2006 Author Report Share Posted April 22, 2006 is there anything wrong with the BB though?I'm talking about a spacer on the axle, a spacer between the bb and frame wouldn't help.oh i didnt no you could get spacers for the axel, this sounds good Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted April 22, 2006 Report Share Posted April 22, 2006 oh i didnt no you could get spacers for the axel, this sounds goodyou get them on FSA platinum pro DH BB... well i did Quote Link to comment Share on other sites More sharing options...
Burton Posted April 22, 2006 Report Share Posted April 22, 2006 Hmm, more reasons to buy a Profile!Sacrafice the freewheel! Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 22, 2006 Report Share Posted April 22, 2006 Not quite sure if I get you, but the best thing you could do is to look for the cause of the problem. There's no logical explenation for it to work fine on the Onza, and not on the Monty. Did you have the cranks screwed in right to the very end of the bb before/now? The Zoo cranks are very very soft and within a matter of weeks they will become loose, so maybe now you can just screw them in further? In adition to that, a 128mm bb should be more than enough. Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted April 22, 2006 Report Share Posted April 22, 2006 Arn't Zoo cranks for a cog only anyway?Try it without the bash, I'm sure you will be able to get it off.Mat Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 22, 2006 Report Share Posted April 22, 2006 Arn't Zoo cranks for a cog only anyway? Nope, they've got lots of thread. Besides the standard build ZOO has/had an ACS freewheel and fixed rear Cranks can either have a short thread (like Monty ones) meaning you can't use a rockring, or a long thread which basically allows you to use both a bashring and freewheel/chainring Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted April 23, 2006 Report Share Posted April 23, 2006 Nope, they've got lots of thread. Besides the standard build ZOO has/had an ACS freewheel and fixed rear Cranks can either have a short thread (like Monty ones) meaning you can't use a rockring, or a long thread which basically allows you to use both a bashring and freewheel/chainringanother reason to go tensile Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted April 23, 2006 Report Share Posted April 23, 2006 Ah rightey, fair enough.Select info just saw that and thought. Lol.Mat Quote Link to comment Share on other sites More sharing options...
