Magura Louise
Synergy
take the old pads out, put a screw driver right through and force the piston down, and leave it to settle for awhile, every thing should be fine, its an open system so the pads ajust to the rotar, and if tehre is no rotar hey presto :P (thank you prawny for educating me)
Edited by Trials mama
Take the old pads out!!! (Y)
nah, only messin wit yall'!!
you have most likely pulled the brake while the wheel is out, and the pistons (being magnetic) have stuck together. so what you need to do is wang a screwdriver in there and pull them apart. then making sure the pads are the right way, put them in and screw the bolt back in through the calliper and the pads to hold them in place
and hey presto!!
joE!
