thirsty2 Posted April 18, 2006 Report Share Posted April 18, 2006 hi i've just got a new Adamant A1, i started to build it up and i got down to doing the brake and i tested the brake bolts in the threads, and they didn't fit. it might be that the paint is hanging over the edge a bit, and i don't want to risk trying to get them in just incase, or are the threads 3 mm, because my ones are 4 mm, the ones you get with the normal echo 4 bolt booster.help would be much appreciated, thanks in advance!!Alex! Quote Link to comment Share on other sites More sharing options...
mat hudson Posted April 18, 2006 Report Share Posted April 18, 2006 its standard, just trust Quote Link to comment Share on other sites More sharing options...
thirsty2 Posted April 18, 2006 Author Report Share Posted April 18, 2006 its standard, just trust so do you recon its just the paint then, ill get the bikeshop where i got it from to do it for me because i get scared when it comes to things like this, because knowing my luck ill muck up.thanks matalex! Quote Link to comment Share on other sites More sharing options...
Caleb Posted April 18, 2006 Report Share Posted April 18, 2006 just try it yourself, you'll need to do it sooner or later anyway and you cant always go to the bike shop . . Quote Link to comment Share on other sites More sharing options...
Dan-Walker Posted April 18, 2006 Report Share Posted April 18, 2006 just try them................so you can come out ridin... Quote Link to comment Share on other sites More sharing options...
DAB Posted April 19, 2006 Report Share Posted April 19, 2006 I can pop over and sort it out for you if you ask..... Quote Link to comment Share on other sites More sharing options...
munkee Posted April 19, 2006 Report Share Posted April 19, 2006 lol i swear people seem to think aluminum is as strong as jelly Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted April 19, 2006 Report Share Posted April 19, 2006 Find someone with a tap set and clean the threads up. Cant hurt Quote Link to comment Share on other sites More sharing options...
thirsty2 Posted April 19, 2006 Author Report Share Posted April 19, 2006 Its all sorted now, i got a cross head screwdriver, and put it in the top and span it to remove the paint, and now they fit. thank you for your help guys.alex!!! Quote Link to comment Share on other sites More sharing options...
