Wheel Swap
Hmmmmmm....? the way i learnt was to back wheel about 3/4 of a bike length away from the ledge then use the momentum from the roll-in to hop on to your nose, you should then still have enough moimentum to nose hop, but reallly push with your knees and use ur arms lift the front end and then you have doene it! takes a while to learn but its quite cool and looks pretty good.
go on to iolobikes.com and download his vid (if its up yet, if not, search for it in the vids section)
he is the best at wheelswaps (or pigeons if your from here), he can do them sooooooo big, probably bigger than vince!! he can do bleeding handrails next to roads for gods sake!!
errmm, well, just watch him and learn.
