munkee Posted April 15, 2006 Report Share Posted April 15, 2006 (edited) Right the rotor is rubbing against the back of the caliper. Not side to side against the pads but its rubbing the actual caliper at the back. Its pissing me the f**k off ive tried centering the rotor a million times but it still does it, either rubs in one place or all the way around. Any ideas? The only way so far ive minimised it is by pulling the whole wheel as far forward in the fork dropouts as i can, but realisticly soon as ido a tap its gonna be pushed back in. Comment welcome.Oh yea its a mono trial 180 Edited April 15, 2006 by Spacemunkee Quote Link to comment Share on other sites More sharing options...
Caleb Posted April 15, 2006 Report Share Posted April 15, 2006 maybe just try dremmeling the rotor down a bit chris?does it on both of my mono's too Quote Link to comment Share on other sites More sharing options...
munkee Posted April 15, 2006 Author Report Share Posted April 15, 2006 Light grind it is.. not gonna go stupid and heat it up and kill it Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted April 15, 2006 Report Share Posted April 15, 2006 I filed fork sropout and pulled the calliper upward a bit. Quote Link to comment Share on other sites More sharing options...
munkee Posted April 15, 2006 Author Report Share Posted April 15, 2006 i ground the edge of the disc down, then ground out the disc mount since the people at echo cant weld straight for shit. Quote Link to comment Share on other sites More sharing options...
David Posted April 15, 2006 Report Share Posted April 15, 2006 Dont you just need your forks facing? Quote Link to comment Share on other sites More sharing options...
munkee Posted April 15, 2006 Author Report Share Posted April 15, 2006 no Quote Link to comment Share on other sites More sharing options...
tom tom Posted April 15, 2006 Report Share Posted April 15, 2006 my 200 does it but my 180 doesnt would be most interested in the cause and solution aswell.tom tom Quote Link to comment Share on other sites More sharing options...
munkee Posted April 15, 2006 Author Report Share Posted April 15, 2006 i think someone at hope cant measure... or perhaps im just a tard.. Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted April 15, 2006 Report Share Posted April 15, 2006 Mine did it cos the disc was oval. Quote Link to comment Share on other sites More sharing options...
tom tom Posted April 15, 2006 Report Share Posted April 15, 2006 i guess this is why hope got rid of their warrenty and outstanding service, too many complaints.tom tom Quote Link to comment Share on other sites More sharing options...
David Posted April 15, 2006 Report Share Posted April 15, 2006 To be honest, I doubt its anything to do with the disk itself? Probably just the forks, is the wheel tightened fully and everything? Quote Link to comment Share on other sites More sharing options...
Alun Goch Posted April 16, 2006 Report Share Posted April 16, 2006 Dont you just need your forks facing? Alun Quote Link to comment Share on other sites More sharing options...
JT! Posted April 16, 2006 Report Share Posted April 16, 2006 Surely it wouldn't take too long to naturally dig it's own groove? Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted April 16, 2006 Report Share Posted April 16, 2006 Has it always been rubbing, or just started? Quote Link to comment Share on other sites More sharing options...
JonPace Posted April 16, 2006 Report Share Posted April 16, 2006 mine used to do this when I had echo urban forks. So I ended up filing down the caliper and all sorts. In the end I sent the forks back and got hifi ones and its fine now. Quote Link to comment Share on other sites More sharing options...
Greetings Posted April 16, 2006 Report Share Posted April 16, 2006 (edited) i ground the edge of the disc down, then ground out the disc mount since the people at echo cant weld straight for shit.seconded, had 06 forks and 06 frames from echo group, none were welded properly, still got a zoo fork where the right stanchion is a few mm ahead of the left one.imo filing the disc mount on the fork is a good idea, wouldn't touch the disc if i were you. the mono trials disc is weak anyway.edit: or just put a small spacer above the hub axle to lower the front wheel a bit Edited April 16, 2006 by Inur Quote Link to comment Share on other sites More sharing options...
