manxrider Posted April 14, 2006 Report Share Posted April 14, 2006 (edited) Ok, so my computer is running 256mb of RDRAM and while I've been looking at prices for upgrading the ram the RDRAM is far more expensive from what I've found. So if I take out the RAM thats already in the computer and say put DDR ram in, is this possible. Screen shots are avalibile from that CPU-Z thing if nessercery. My computer is the Dell Dimension 8250. Thanks for any help . Edited April 15, 2006 by manxrider Quote Link to comment Share on other sites More sharing options...
Monkey Posted April 15, 2006 Report Share Posted April 15, 2006 (edited) RDRAM IS more expensive. It isn't DDR memory - they are RIMMs rather that DIMMs - and has different numbers of pins and different recesses because it's a completely different type of memory (DDR won't fit).Try EBay Items matching ( rdram ) if you haven't already. On the computers I've had with RDRAM you need to add it in pairs and any empty slots need to be filled with a pair of CRIMMS (just zero memory circuit boards so that everything is filled - they are cheaper but you may already have a pair inside). CPU-Z will tell you what speed the memory is. I've had a quick look at Dimension 8250 and the spec seems like one you want to keep... Edited April 15, 2006 by Monkey Quote Link to comment Share on other sites More sharing options...
manxrider Posted April 15, 2006 Author Report Share Posted April 15, 2006 OK, thanks. Suppose I better just cough up some more money .Yeh everything else on the computer is fine, except the 256 ram. Thanks anyway Quote Link to comment Share on other sites More sharing options...
