ridelife Posted April 14, 2006 Report Share Posted April 14, 2006 wat is the best gearing on a mod??ive got a onza t mag 2004 and i am running 16/21 but i think it is too easy for what i want to do!!so need help!cheers dan! Quote Link to comment Share on other sites More sharing options...
T-BAD Posted April 14, 2006 Report Share Posted April 14, 2006 get a 18tooth front freewheel, then a rear fixed 12 tooth sprocket, Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted April 14, 2006 Report Share Posted April 14, 2006 18:1218:13, depending on your cranks.Mat Quote Link to comment Share on other sites More sharing options...
Mr_Pitbull Posted April 14, 2006 Report Share Posted April 14, 2006 175mm Cranks if your Mod frame is farely long. Makes it flick up alot easier. Quote Link to comment Share on other sites More sharing options...
ridelife Posted April 14, 2006 Author Report Share Posted April 14, 2006 any specific freewheel????cheers dan! Quote Link to comment Share on other sites More sharing options...
JT! Posted April 14, 2006 Report Share Posted April 14, 2006 wat is the best gearing on a mod??ive got a onza t mag 2004 and i am running 16/21 but i think it is too easy for what i want to do!!so need help!cheers dan! 21 up front and a 16t freewheel i assume? That gives u a gear ratio of 1.3 which is quite low.Most people have a gear ratio of 1.5, which is usually 18 up front and 12 on the rear. An 18 tooth freewheel on the cranks and a 12t cog on the rear.any specific freewheel????cheers dan!Maby get a 18t freewheel and screw it on your cranks and get a 12t cog for the rear? The whole setup wont cost you anything over £30 inc all the postage costs.What cranks have you got?175mm Cranks if your Mod frame is farely long. Makes it flick up alot easier.That's just silly. Quote Link to comment Share on other sites More sharing options...
planet x alan Posted April 15, 2006 Report Share Posted April 15, 2006 surely this sorta thing depends on the riders preference? and 175mm crank arms on a mod is crazy Quote Link to comment Share on other sites More sharing options...
M3LLON_t-mag Posted April 15, 2006 Report Share Posted April 15, 2006 best gearing for a mod has to be an 18tooth reliable freewheel on the front eg.white industries and a 12tooth screw on sprocket on the back with short crank arms as it gives you more power and your legs dont have to travel as far when kick for a big hopcheersmellon Quote Link to comment Share on other sites More sharing options...
Technical Tom Posted April 15, 2006 Report Share Posted April 15, 2006 (edited) At the moment i run 22:16 which is perfect, but now that i'm getting super pro trials cranks it's going to be 16:12 i think i will need now. Also it's defiantly rider preference, some people pefere harder gearing than others. Tom. Edited April 15, 2006 by onza_tom123 Quote Link to comment Share on other sites More sharing options...
