19" 36h Rim
PaRtZ
After a few...errr....attempts I have a "couple" of flat spots on the ronnie so Im after another 36h rim (profile) I just want something that is strong as fook for a fatty like me
So can I have your suggestions please. Dont say ronnie :P
depends if you want streghth/width/or gindability. or a mix...
if you want strength, grindablilty and width, u need to get a 32h hub basically.
otherwise u can get a rim with any two of the three mentioned properties with a 36h hub.
its a sucky situation i know, but i was in your boots a few months ago...
monty :)
he said strong ben :P monty rims suck, unless they have released a new rim im not aware of?
I'm not sure if it is but DX32, I'm sure my mate has got one on his bike as he runs a profile and their 32h right?
they come in 36h too, and imo are the best rear mod rim out (Y) grinds well and is strong :)
So are these kris holm rims better than a alex dx32?
I've personally never used one but I know the kris holm rim is very very good, very well made and very strong. Only reason I don't have it on my bike is to make a little lighter and rim a smooth rim.
Everyone came to the conclusion that the Kris holme rim has a hog with a line on the braking surface, much like the V!z rims.
Echo rims are shite as well.
So its either DX32 for bit better quality grind, or a hog/v!z/koxx rim which are wider, and dont grind as nice?( :ermm::huh: ) But they do grind well, and i aint had no problems with me Coustsinks on it.
Kris Holm rims don't come with a brake line indicator on the sidewall, yes they are the strongest rims, muchos stronger than DX32s. Great rims, £22 from Unicycle UK, sorted (Y)
Unicycle trials rims make most bike trials rims look as weak as a granny. I've had about 5 of them, all built onto different hubs, sold them etc. and they are still going strong with their new owners.
.... And going back to what dan tlite said.... Kris Holm rims are NOT Hog rims, that is absolute bull, they are narrower than Hog rims and have a slightly different shape to them, and for the last time, KH rims do not have brake line indicators :rolleyes: . Official Facts.
Edited by unstablebutable
official facts?
see: http://www.trials-forum.co.uk/forum/index....35entry781635
i quote:
Mike Poyzer @ Onza: "We collaborate a lot with Kris Holm on Unicycle projects and I can tell you that the rim is exactly the same rim as the Onza ground hog without the hole drillings. It is also the same as the Viz, Koxx and several others. I believe that the wear line is being dropped as he has had several failures with rims splitting along the wear line. This is not a good feature for trials riders. If we produced the rim without drillings or side wall grinds it would be about the same price"
the company that makes the hog, koxx, viz, holm rims is called hsin chuan. i have dealt with them and they will make the rim in a variety of widths, in a variety of drillings, including hole shape, with/without brake line indicator, and with anodizing or powder coating (such as vincent's dayglo and white rims). in the end, it is the same damn alloy pushed through a different die and with a different drill bit in. they are all the same.
Edited by durkie
Whatever anyone says, the Kris Holm rim is still not the same as the Hog... people say the Hog is the same as the Koxx and Viz rims right? Well, we compared some rims at a friend's house, and the KH rim is definitely different to the Hog and Koxx rims, for starters you can see that the KH rim is narrower, plus the middle ridge in the KH rim curves up a bit more.
Roger Davies, the owner of Unicycle UK shop, confirmed to my friend Joe (who is sponsored by Unicycle.com) that the KH rim is different to the Viz rims, and Hog rims. And Roger is pretty much the grandfather of all knowledge when it comes to Unicycle parts, hog rim included.
Maybe on paper KH rims are the same as Hog... but in real life they're different in width and shape. And going back to 'the same damn alloy'... Roger Davies confirmed to Joe that the KH rim is made of a different alloy to Viz, Hog, and Koxx rims. Also changing the width of a rim makes the rim different, it's as stupid as saying a Zoo mod stem is the same as an Echo Team stem.
Edited by Sponge
you have your reference and i have mine. i'll make sure to keep an eye out for people recommending viz over koxx or the holm over the hog because soandso got the width and center ridge size just right and it makes for a tremendous difference in strength. :)
i find it strange and very doubtful that kris holm, in an even more niche market than bicycle trials, would have this company go clearly out of its way to make this rim out of something other than 6061 (since all of their other rims are made of 6061), especially given the blatantly obvious cheesiness of the koxx/viz rims. something tells me your 3rd hand source is sketchy.
in the end, the dx-32 is the only one made of 7075, with the exception of maybe the echos. that's what's going to last.
official facts?
i quote:
Don't worry matt, the one up there has split where the wear line was. You're gonna have pants grinds now too :P Buy an echo rim then the sexy blueness will be complete!
