KONA_MAN_THE_RESURECTION Posted April 12, 2006 Report Share Posted April 12, 2006 Can you use a hs33 lever on a hs11 brake?? Quote Link to comment Share on other sites More sharing options...
ogre Posted April 12, 2006 Report Share Posted April 12, 2006 I should think so, you can use the hs33/11 pistons on a hs33/11 so i don't see why not just try it, i think the only differance between the hs33 and hs11 is that the hs11 is made of plastic or something, i could be wrong though. Quote Link to comment Share on other sites More sharing options...
KONA_MAN_THE_RESURECTION Posted April 12, 2006 Author Report Share Posted April 12, 2006 Can you use a hs33 lever on a hs11 brake??Yea Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted April 12, 2006 Report Share Posted April 12, 2006 Yes. All the cylinders are the same. Quote Link to comment Share on other sites More sharing options...
KONA_MAN_THE_RESURECTION Posted April 12, 2006 Author Report Share Posted April 12, 2006 Can you use a hs33 lever on a hs11 brake??Yeah the hs11 lever is plastic.I'll try it out cheers Yes. All the cylinders are the same. Don't suppose you know anyone with a set forsale? Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted April 12, 2006 Report Share Posted April 12, 2006 Yeah the hs11 lever is plastic.I'll try it out cheers Don't suppose you know anyone with a set forsale? 1. You answered yourslef...twice? 2. No forsale/wanted threads in NMC. Quote Link to comment Share on other sites More sharing options...
ManxTrialSpaz Posted April 12, 2006 Report Share Posted April 12, 2006 Someone forgot to change to their validation accounts Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted April 12, 2006 Report Share Posted April 12, 2006 hs11 uses a different sized fitting into the lever to the hs33, so you will need a new hose end too Quote Link to comment Share on other sites More sharing options...
Bike addict Posted April 12, 2006 Report Share Posted April 12, 2006 yeah it should work, i don't see why not, they are BASICALLY the same. Quote Link to comment Share on other sites More sharing options...
