T-mag -yay Or Nay -
ryan i think you should get the T-pro
because it is cheaper than the T-mag
i think the T-pro is better and so do
most people and because it's cheaper
you will have money left over to do it up
stick some well mean parts on it so i say the
T-pro
scott
Edited by Scotty H
The T-Pro's aren't exactly strong either.
I cracked my one.
Many have cracked them. Even smooth riders.
If you're just starting off, and if you're not so bothered about weight, get the T-Mag.
If you are bothered about weight, go for the T-Pro.
The T-Mag is shorter then the T-Pro, unfortunatley i'm unsure on the wheelbase.
But my T-Pro was 1000mm, with Onza straight Alu forks.
I think the T-MAg is slightly smaller...
I can't really see how the t-mag 'weights a ton'. It feels the same as my t-lite, with echo lite forks and koxx wheels. I wouldn't let weight be a factor in your decision.
